I'm new to GeoServer but I have been able to get it up and running and
connecting to my SQL Server 2008 R2. I am working through the Book
"GeoServer Beginner's Guide" from Packt Publishing. I figured out how to
get the U.S. Census Counties shape file in to SQL Server and it shows as
spatial objects in SQL management studio so I think the data is OK.
My first problem is that when I ask it to compute the bounding box from data
I get the following:
/Oops, something went wrong...
Sorry, something unexpected happened on the server.
Here's an error report you can include in a JIRA bug report about this
issue:
java.lang.RuntimeException: java.io.IOException: Error occured calculating
bounds at
org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:508)/
Ok so I go ahead and enter the bounding box manually and and I am able to
publish the layer. However,
now when I preview the layer it is blank and when I click in the map area I
get the following:
/Internal error occurred java.io.IOException null A .NET Framework error
occurred during execution of user-defined routine or aggregate "geometry":
System.ArgumentException: 24144: This operation cannot be completed because
the instance is not valid. Use MakeValid to convert the instance to a valid
instance. Note that MakeValid may cause the points of a geometry instance to
shift slightly. System.ArgumentException: at
Microsoft.SqlServer.Types.SqlGeometry.ThrowIfInvalid() at
Microsoft.SqlServer.Types.SqlGeometry.STIntersects(SqlGeometry other) at
Microsoft.SqlServer.Types.SqlGeometry.Filter(SqlGeometry other) . /
Apparently this was a problem back in 2010 with version 2.0.2. I am running
version 2.3.2. on windows server 2008 R2 and SQL Server 2008 R2 I don't want
to post a JIRA bug report, because I'm to new of a user to tell if it is a
bug or something I'm doing wrong.
Mark
View this message in context: http://osgeo-org.1560.x6.nabble.com/SQL-Server-Problem-tp5060024.html
