[Geoserver-users] SQL Server
Thank you Ian. It is good to know for sure.
I am not able to find the SQL Server extension though. The links in the docs are broken.
JJ
The Jenkins server tests against SQLServer 2014 so yes it is supported, the only issue I know of is that you can’t use the open source JDTS driver with 2014 (yet).
Ian
On Thu, Jul 2, 2015 at 10:27 PM jair santos <jairds@anonymised.com> wrote:
Does anybody knows if SQL Server 2014 is supported by Geoserver SQL Server extension?
thanks
JJ
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/_______________________________________________
Geoserver-users mailing list
Which docs are broken? The ones at http://docs.geoserver.org/stable/en/user/data/database/sqlserver.html#sqlserver-install all seem to work for me.
Ian
JJ
Ian
thanks
JJ
