On Mon, Oct 6, 2014 at 9:35 AM, Begoña <begodom@anonymised.com> wrote:
Hi
This is my geoserver information:
- Información de compilación
- Version 2.5
- Revisión de Git 8cf3edcf5f61db010f7ad3fcb4613e7c0eabeaff
- Fecha de compilación 18-Mar-2014 16:08
- Versión de GeoTools 11.0 (rev
fb9a2d3f88315d076523788cb8196ec89bb253f9)
- GeoWebCache Version 1.5.1 (rev
1.5.x/64246c20a4ada1c954b17d23b9447408d1c5432f)
But I am confused because last week I upgraded to GeoServer 2.5.2
The above is 2.5.0, so the upgrade failed.
A working upgrade should also fix the issue with the sql views.
How did you try to do the upgrade?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
