No, it is unknown to Geoserver. What it is for a projection? Obviously it is not an EPSG-projection nor Oracle SRID. Do you know the parameters of your SRID? You can look examples of different ways for giving the parameters from the links in http://spatialreference.org/ref/epsg/3067/
-Jukka Rahkonen-
Steven Campbell wrote:
Hi
Does anyone know if GeoServer use the SRID 89189?
Thanks
Steve
Steve Campbell | GIS Manager
Corporate Strategy and Communications
Borough of Poole | Civic Centre | Poole BH15 2RU
Tel: 01202 633 362
Email: s.campbell@anonymised.com
Website:www.boroughofpoole.com
Think Green! Please Recycle
DISCLAIMER: This email and any files transmitted with it may be confidential, legally privileged and protected in law and are intended solely for the use of the individual to whom it is addressed. The copyright in all documentation is the property of the Borough of Poole and this email and any documentation must not be copied or used other than as strictly necessary for the purpose of this email, without prior written consent which may be subject to conditions. Any view or opinions presented are solely those of the author and do not necessarily represent those of the Borough of Poole. The Borough of Poole reserves the right to inspect incoming and outgoing emails. If you have received this email in error please contact the sender by return and confirm that its contents have been destroyed. Telephone enquiries should be directed to the Borough switchboard on 01202 633633.’
Hi Jukka
Apologies I meant to write 81989, do you know if GeoServer works with 81989?
Thanks
Steve
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@anonymised.com.]
Sent: 09 April 2014 12:44
To: Steven Campbell; geoserver-users@lists.sourceforge.net
Subject: Re: SRID 89189 and Geoserver
-Jukka Rahkonen-
Hi
Thanks
Steve
Tel: 01202 633 362
apparently it is not known by default, but you can add it’s definition to $GEOSERVER_DATA_DIR/user_projections/epsg.properties.
Br,
Tuomas Koivusalo
From: Steven Campbell [mailto:s.campbell@anonymised.com]
Sent: 9. huhtikuuta 2014 14:51
To: ‘Rahkonen Jukka (Tike)’; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] SRID 89189 and Geoserver
Hi Jukka
Thanks
Steve
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@anonymised.com]
-Jukka Rahkonen-
Hi
Thanks
Steve
Tel: 01202 633 362
