That is not an EPSG projection either. I guess it is Oracle SRID and described here
https://community.oracle.com/thread/2210240?start=0&tstart=0
Based on that mail the difference does not look big and I believe that for WMS they could be used as synonyms.
Geoserver does not know 81989 but it knows EPSG:27700 with the following parameters
PROJCS[“OSGB 1936 / British National Grid”,
GEOGCS[“OSGB 1936”,
DATUM[“OSGB 1936”,
SPHEROID[“Airy 1830”, 6377563.396, 299.3249646, AUTHORITY[“EPSG”,“7001”]],
TOWGS84[446.448, -125.157, 542.06, 0.15, 0.247, 0.842, -20.489],
AUTHORITY[“EPSG”,“6277”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4277”]],
PROJECTION[“Transverse_Mercator”, AUTHORITY[“EPSG”,“9807”]],
PARAMETER[“central_meridian”, -2.0],
PARAMETER[“latitude_of_origin”, 49.0],
PARAMETER[“scale_factor”, 0.9996012717],
PARAMETER[“false_easting”, 400000.0],
PARAMETER[“false_northing”, -100000.0],
UNIT[“m”, 1.0],
AXIS[“Easting”, EAST],
AXIS[“Northing”, NORTH],
AUTHORITY[“EPSG”,“27700”]]
I do not know what to do if you have SRID=81989 in Oracle but Geoserver knows only 27700. Perhaps you must add a custom projection with code 81989 into your Geoserver by copying the parameters from 27700.
-Jukka Rahkonen-
Steven Campbell wrote:
Hi Jukka
Apologies I meant to write 81989, do you know if GeoServer works with 81989?
Thanks
Steve
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@anonymised.com]
Sent: 09 April 2014 12:44
To: Steven Campbell; geoserver-users@lists.sourceforge.net
Subject: Re: SRID 89189 and Geoserver
No, it is unknown to Geoserver. What it is for a projection? Obviously it is not an EPSG-projection nor Oracle SRID. Do you know the parameters of your SRID? You can look examples of different ways for giving the parameters from the links in http://spatialreference.org/ref/epsg/3067/
-Jukka Rahkonen-
Hi
Does anyone know if GeoServer use the SRID 89189?
Thanks
Steve
Steve Campbell | GIS Manager
Corporate Strategy and Communications
Borough of Poole | Civic Centre | Poole BH15 2RU
Tel: 01202 633 362
Email: s.campbell@anonymised.com
Website:www.boroughofpoole.com
Think Green! Please Recycle
DISCLAIMER: This email and any files transmitted with it may be confidential, legally privileged and protected in law and are intended solely for the use of the individual to whom it is addressed. The copyright in all documentation is the property of the Borough of Poole and this email and any documentation must not be copied or used other than as strictly necessary for the purpose of this email, without prior written consent which may be subject to conditions. Any view or opinions presented are solely those of the author and do not necessarily represent those of the Borough of Poole. The Borough of Poole reserves the right to inspect incoming and outgoing emails. If you have received this email in error please contact the sender by return and confirm that its contents have been destroyed. Telephone enquiries should be directed to the Borough switchboard on 01202 633633.’
