[Geoserver-users] srs 900913
All,
I'm running geoserver 1.6.4. I'm trying to output wms in srs 900913 (google
maps projection). I added the srs definition to spatial_ref_sys in postgis
and to the epsg.properties table in geoserver. But if I make a WMS request,
I don't get anything returned...no image, no error in the logs. Any
thoughts?
Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
What’s your WMS request look like?
On Mon, Oct 27, 2008 at 1:05 PM, Stephen Crawford <src176@anonymised.com> wrote:
All,
I’m running geoserver 1.6.4. I’m trying to output wms in srs 900913 (google
I don’t get anything returned…no image, no error in the logs. Any
thoughts?
Steve
Stephen Crawford
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Hi Stephen,
You should not have to play with the postgis spatial_ref_sys table unless your data is actually in the google maps projection. As well 900913 should be already included in the epsg.properties file as well.
All you should have to do is issue the request with the parameter "SRS=EPSG:900913" and also ensure the "BBOX" parameter is in the 900913 projection.
If you are seeing a blank image it more often then not means that your postgis table does not have the correct projection set on it, or you are issuing the request in incorrect coordinates. What is the native projection of your data?
-Justin
Stephen Crawford wrote:
All,
thoughts?
Steve
Stephen Crawford
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
I was making a bone-head mistake in sending the bbox in lon-lat instead of
meters....it's all good. Thanks for for the help.
Steve
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Monday, October 27, 2008 5:52 PM
To: Stephen Crawford
Subject: Re: [Geoserver-users] srs 900913
Hi Stephen,
projection.
of your data?
-Justin
All,
(google maps projection). I added the srs definition to
spatial_ref_sys in postgis and to the epsg.properties table in
geoserver. But if I make a WMS request, I don't get anything
returned...no image, no error in the logs. Any thoughts?
Steve
Stephen Crawford
--- This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge Build the coolest Linux based applications with Moblin SDK &
win great prizes Grand prize is a trip for two to an Open Source event
Justin Deoliveira
prizes Grand prize is a trip for two to an Open Source event anywhere in the
world http://moblin-contest.org/redirect.php?banner_id=100&url=/
