Dear all,
we want to start using geoserver. Checking the SRSList I found out that the parameters for geocentric translation for the projection are not the ones we are using.
Does anyone know how I can change the parameters?
BRGDS
Karl
Dear all,
BRGDS
Karl
Tiller.Karl@anonymised.com ha scritto:
Dear all,
Yeah, there is an undocumented feature that allows one to ovveride
the parameters we get from the official EPSG database.
If you look into your GeoServer data directory you'll find
a user_projections directory with an epsg.properties file.
That one allows users to add custom projections.
If you create a epsg_overrides.properties file with the
same inner sytanx you'll be able to specify official epsg
codes in it, and they will override the standard EPSG database
as opposed to just adding what's not already there.
See also these instructions on the usage of the epsg.properties
file:
http://geoserver.org/display/GEOSDOC/Custom+projection+definition+in+Geoserver+1.5.0+(onwards)
(follow them, but work with the epsg_overrides file instead).
Andrea Aime
OpenGeo - http://opengeo.org
