[Geoserver-users] srsName missing with Geometries when using app-schema
Hello,
we are using geoserver version 2.7.1.1 and the related app-schema plugin.
We are also using the oracle plugin to retrieve the data.
When we map a geometry type (SDO_GEOMETRY) to a gml:geometry (e.g. gml:Point) the outcome is as expected in general but the attribute srsName is missing.
We made sure, that the information is available within the SDO_GEOMETRY type and –using a debugger- we made sure it is available within the app-schema plugin.
Nevertheless it is not output to the generated XML stream.
There seems to be a related bug (with fix) in the geotools (https://osgeo-org.atlassian.net/browse/GEOT-2639).
Does anybody know when this fix will have made its way into a geoserver release?
Best regards
Gerhard Duennebeil
GERHARD DÜNNEBEIL
Secure Information Management
Safety & Security Department
AIT Austrian Institute of Technology GmbH
Donau-City-Straße 1 | 1220 Vienna | Austria
T +43(0) 50550-3173 | M +43(0) 664 2351747 | F +43(0) 50550-4150
gerhard.duennebeil@anonymised.com | http://www.ait.ac.at
FN: 115980 i HG Wien | UID: ATU14703506
http://www.ait.ac.at/Email-Disclaimer
Hello,
Best regards
Gerhard Duennebeil
> GERHARD DÜNNEBEIL
Would you also be able to confirm that you have updated
USER_SDO_GEOM_METADATA
http://docs.oracle.com/cd/B19306_01/appdev.102/b14255/sdo_objrelschema.htm
Sent: Friday, 10 July 2015 4:18 PM
To: Gerhard.Duennebeil@…7146…
Subject: Re: [Geoserver-users] srsName missing with Geometries when using app-schema
Hi Dünnebeil,
works for me on GeoServer 2.7.1 with a PostGIS-backed layer.
Request is:
http://localhost:8080/geoserver/ows?service=WFS&version=2.0.0&request=GetFeature&typeName=lcv:LandCoverUnit&maxFeatures=50&srsName=EPSG:4326
Sample output:
<wfs:FeatureCollection numberMatched=“unknown”
numberReturned=“1044” timeStamp=“2015-07-10T08:00:45.387Z”
xsi:schemaLocation=“http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd http://inspire.ec.europa.eu/schemas/lcv/3.0 http://inspire.ec.europa.eu/schemas/lcv/3.0/LandCoverVector.xsd http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd”>
wfs:member
<lcv:LandCoverUnit gml:id=“lcu.15766”>
lcv:inspireId
base:Identifier
base:localIdf9f3fb10-980f-11e4-9126-1b2d9c2751a0</base:localId>
base:namespacelcu</base:namespace>
</base:Identifier>
</lcv:inspireId>
lcv:geometry
<gml:MultiSurface srsDimension=“2”
srsName=“http://www.opengis.net/gml/srs/epsg.xml#4326”>
gml:surfaceMember
<gml:Polygon srsDimension=“2”>
gml:exterior
gml:LinearRing
gml:posList
10.265245506969334
43.81816641231743
10.265182592170541
43.81805635449135
10.265245506969334
43.81816641231743
</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gml:surfaceMember>
</gml:MultiSurface>
</lcv:geometry>
lcv:landCoverObservation
lcv:LandCoverObservation
lcv:class243</lcv:class>
lcv:observationDate2007-01-01T00:00:00Z</lcv:observationDate>
</lcv:LandCoverObservation>
</lcv:landCoverObservation>
lcv:observationDate2013-01-01T00:00:00Z</lcv:observationDate>
</lcv:LandCoverUnit>
</wfs:member>
</wfs:FeatureCollection>
Perhaps the problem occurs only when the layer is served by Oracle?
Could you prepare a minimal sample dataset and app-schema mapping file to reproduce the error?
Best regards,
Stefano Costa
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Da: “Dünnebeil Gerhard” Gerhard.Duennebeil@…7146…
A: “geoserver-users@lists.sourceforge.netgeoserver-users@lists.sourceforge.net
Cc:
Data: Fri, 10 Jul 2015 06:52:36 +0000
Oggetto: [Geoserver-users] srsName missing with Geometries when using app-schema
Hello,
Best regards
Gerhard Duennebeil
> GERHARD DÜNNEBEIL
> gerhard.duennebeil@…7146… | http://www.ait.ac.at
