I haven’t a Shibboleth base SSO infrastructure, I need to create one or use any other solutions which allow me to implement SSO authentication with Geoserver.
Thanks in advance for your hep,
Kamardine
Envoyé : jeudi 22 janvier 2015 16:37
Hi Kamardine,
2015-01-22 16:30 GMT+01:00 Kamardine YOUSSOUFA <Kamardine.YOUSSOUFA@anonymised.com>:
I want to implement a Shibboleth infrastructure in order to manage SSO authentication with Geoserver. It would seems that it is possible.
I found some documentation in this link http://www.geo-solutions.it/blog/developers-corner-configuring-geoserver-work-shibboleth-ldap/
I personally wrote the blog post and participated to an integration of Shibboleth SSO with GeoServer for one of our customers.
So I can tell you that it can be done. It’s not so simple (mostly installing and configuring Shibboleth it’s the most complex part, in my opinion, while integrating it with Geoserver was simpler).
It all depends on what are your specific requirements and your situation: do you already have a Shibboleth base SSO infrastructure or need to create one?
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
