[Geoserver-users] ST_GEOMETRY in Oracle
Does anyone have any experience of using geoserver to connect to a table in
Oracle that has been spatially enabled using SDE. The table is called
TEST_QUAKE and is in the BEN schema and is populated with 5000 records.
Name Null? Type
EVENT_ID NUMBER(11)
LAT NUMBER(8,5)
LON NUMBER(8,5)
SHAPE BEN.ST_GEOMETRY
OBJECTID NOT NULL NUMBER(38)
PK NOT NULL NUMBER(5)
When I create a data store (selecting Oracle in the Feature Data Set
Description) called quake and then try to create a new FeatureType from
available DataStores and select quake::TEST_QUAKE i only see the following 4
fields: EVENT_ID, LAT, LON, OBJECTID. PK and SHAPE are not listed.
Generating a bounding box yields the following error: The FeatureType
'TEST_QUAKE' has a NULL extent. HINT: the dataset is empty or has no default
geometry attribute.
Is there a subtle issue here or does geoserver just not understand the ESRI
spatial type?
Many thanks
Paul
View this message in context: http://www.nabble.com/ST_GEOMETRY-in-Oracle-tf4644885.html#a13267845
Name Null? Type
EVENT_ID NUMBER(11)
LAT NUMBER(8,5)
LON NUMBER(8,5)
geometry attribute.
spatial type?
The second. The Oracle data store understands only SDO_GEOMETRY.
Yet, if you have SDE, you can connect GeoServer to ArcSDE using
the plugin you can find in the "extension datastores" downloads.
Hope this helps
Cheres
Many thanks for that Andrea. I guess we'll be looking into the options of
connecting to SDE, forking out for Oracle Spatial or looking into synching
Oracle with Postgres.
Best regards
Paul
in
Name Null? Type
EVENT_ID NUMBER(11)
LAT NUMBER(8,5)
LON NUMBER(8,5)
following 4
default
geometry attribute.
ESRI
spatial type?
Hope this helps
Cheres
Geoserver-users mailing list
View this message in context: http://www.nabble.com/ST_GEOMETRY-in-Oracle-tf4644885.html#a13283347
