Hi Volkan,
If I understand you correctly (not sure I do, though), I don't think you need GeoServer at all. Simply enable "fullWMS" in a standalone GeoWebCache installation, cf. "Support for Regular WMS Clients" here http://geowebcache.org/docs/1.5.1/services/wms.html
/julian
-----Oprindelig meddelelse-----
Fra: Volkan Gümüs [mailto:hallo@…7451…]
Sendt: 8. april 2016 10:12
Til: geoserver-users <geoserver-users@lists.sourceforge.net>
Emne: Re: [Geoserver-users] Standalone GeoWebCache
Hi Julian,
I'm not sure if Cascading WMS is the right approach.
I want to achieve the same as if I would have used the integrated GeoWebCache.
WMS -> Tile cached
yes -> return cached tile
no -> create cached tile in geowebcahe
But the Cache should be on another system, so I can connect more than 1 GeoServer to the GeoWebCache.
Am 08.04.2016 um 09:43 schrieb Julian Hollingbery:
Depending on your exact use case, this might be what you need: Enable "FullWMS" in GeoWebCache, and use it to produce a so-called "Cascading WMS":
http://docs.geoserver.org/latest/en/user/data/cascaded/wms.html
/julian
Sendt: 8. april 2016 09:24
Emne: [Geoserver-users] Standalone GeoWebCache
how can I connect my GeoServer instance to my standalone GeoWebCache instance?
I found instructions to configure layers in GeoWebCache using GetCapabilities, but there's no document for connecting GeoServer WMS to GeoWebCache.
Regards
Beste Grüße
Volkan Gümüs
F1-Computer.de
Tel: 0231 223 985 60
Fax: 0231 330 295 08
Mail: hallo@...7451...
-------- _______________________________________________
Geoserver-users mailing list
Beste Grüße
Volkan Gümüs
F1-Computer.de
