Hi Kris
Yes, I already stopped Tomcat, then removed the existing geoserver-devel.war and geoserver-devel directory and the geoserver-devel directory from work/Catalina/localhost/. Shouldn’t the “update sequence” on the upper left corner of the UI go back to zero?
I works with the default geoserver directory…?
regards
Stefan
Von: Kris Geusebroek [mailto:kgeusebroek@anonymised.com]
Gesendet am: Mittwoch, 11. März 2009 09:50
An: Ziegler Stefan; geoserver-users
Betreff: RE: [Geoserver-users] startup problems with 1.7.3Hi Stefan,
I just deployed 1.7.3 on my local tomcat and having no problems at all.
Is it possible that an old version was installed and is bothering you now.
If you put the war in the webapps dir make sure you stop tomcat first and delete the expanded (geoserver directory in webapps) version and also remove the geoserver directory from work/Catalina/localhost directory (or similar)
Then start.
Hope this helps
Kris
From: Ziegler Stefan [mailto:Stefan.Ziegler@anonymised.com]
Sent: Wednesday, March 11, 2009 8:39 AM
To: geoserver-users
Subject: [Geoserver-users] startup problems with 1.7.3Hi
I’m not able to run the latest GeoServer (1.7.3) with a different data directory. I set the data directory in the web.xml and restarting Apache Tomcat results in this error:2009-03-11 08:24:16,455 WARN [geoserver.confg] - Error occured loading service: wms
2009-03-11 08:24:17,632 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘wmsConfig’ defined in URL [jar:file:/usr/l
ocal/apache-tomcat-5.5.25/webapps/geoserver-devel/WEB-INF/lib/wms-1.7.3.jar!/applicationContext.xml]: Instantiation of bean failed
; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.c
onfig.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)The data directory is copied from a different server where GeoServer 1.7.2 is running.
We are using Apache Tomcat 5.5 on a Linux machine and there is already an old GeoServer running. So I renamed the new one to geoserver-devel.war. Any help is appreciated!
regards
StefanMit freundlichem Gruss
Stefan Ziegler
Leiter AufsichtKanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
