I started copying all the old stuff into the new directory and found out that it’s the coverage directory that is responsible for the failure. Since I only had two coverages I just created them again.
Stefan
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet am: Mittwoch, 11. März 2009 14:00
An: Ziegler Stefan
Cc: geoserver-users; kgeusebroek
Betreff: Re: [Geoserver-users] startup problems with 1.7.3
The update sequence should stay the same if you are using an existing
data directory. As Kris states I would ensure all temp
directories are
removed. Also if you could include the entire start up log that might
help us spot the problem.
-Justin
Ziegler Stefan wrote:
Hi Kris
Yes, I already stopped Tomcat, then removed the existing
geoserver-devel.war and geoserver-devel directory and the
geoserver-devel directory from work/Catalina/localhost/.
Shouldn’t the
“update sequence” on the upper left corner of the UI go
back to zero?
I works with the default geoserver directory…?
regards
Stefan
Von: Kris Geusebroek [mailto:kgeusebroek@anonymised.com]
Gesendet am: Mittwoch, 11. März 2009 09:50
An: Ziegler Stefan; geoserver-users
Betreff: RE: [Geoserver-users] startup problems with 1.7.3
Hi Stefan,
I just deployed 1.7.3 on my local tomcat and having no
problems at all.
Is it possible that an old version was installed and is
bothering
you now.
If you put the war in the webapps dir make sure you stop tomcat
first and delete the expanded (geoserver directory in webapps)
version and also remove the geoserver directory from
work/Catalina/localhost directory (or similar)
Then start.
Hope this helps
Kris
From: Ziegler Stefan [mailto:Stefan.Ziegler@anonymised.com]
Sent: Wednesday, March 11, 2009 8:39 AM
To: geoserver-users
Subject: [Geoserver-users] startup problems with 1.7.3
Hi
I’m not able to run the latest GeoServer (1.7.3) with a
different
data directory. I set the data directory in the web.xml and
restarting Apache Tomcat results in this error:
2009-03-11 08:24:16,455 WARN [geoserver.confg] - Error occured
loading service: wms
2009-03-11 08:24:17,632 ERROR [context.ContextLoader] - Context
initialization failed
org.springframework.beans.factory.BeanCreationException: Error
creating bean with name ‘wmsConfig’ defined in URL
[jar:file:/usr/l
ocal/apache-tomcat-5.5.25/webapps/geoserver-devel/WEB-INF/lib/
wms-1.7.3.jar!/applicationContext.xml]:
Instantiation of bean failed
; nested exception is
org.springframework.beans.BeanInstantiationException: Could not
instantiate bean class [org.vfny.geoserver.c
onfig.WMSConfig]: Constructor threw exception; nested
exception is
java.lang.NullPointerException
at
org.springframework.beans.factory.support.ConstructorResolver.
autowireConstructor(ConstructorResolver.java:254)
The data directory is copied from a different server
where GeoServer
1.7.2 is running.
We are using Apache Tomcat 5.5 on a Linux machine and there is
already an old GeoServer running. So I renamed the new one to
geoserver-devel.war. Any help is appreciated!
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Apps built with the Adobe(R) Flex(R) framework and Flex
Builder™ are
powering Web 2.0 with engaging, cross-platform
capabilities. Quickly and
easily build your RIAs with Flex Builder, the
Eclipse™based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Ok. That makes sense. I don;t have coverages so I had no problems.
Glad you found it.
Cheers Kris
Sent: Wednesday, March 11, 2009 2:05 PM
To: jdeolive
Cc: geoserver-users; Kris Geusebroek
Subject: AW: Re: [Geoserver-users] startup problems with 1.7.3
Stefan
An: Ziegler Stefan
directories are
-Justin
Hi Kris
Shouldn’t the
back to zero?
regards
Stefan
Hi Stefan,
problems at all.
bothering
you now.
Then start.
Hope this helps
Kris
To: geoserver-users
Hi
different
[jar:file:/usr/l
exception is
at
where GeoServer
1.7.2 is running.
regards
Stefan
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Rötistrasse 4
4501 Solothurn
http://www.so.ch
Builder™ are
Justin Deoliveira
