[Geoserver-users] strange getFeatureBBOX behaviour
Hi GeoServer people,
I am getting strange behaviour with the WFS_getFeatureBBOX.url.
Either the WFS request doesn’t return what it should, or I am missunderstanding what it is designed for.
In GeoServer Demo Request, the WFS_getFeatureBBOX.url is :
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=topp:states&propertyName=STATE_NAME,PERSONS&BBOX=-75.102613,40.212597,-72.361859,41.512517,EPSG:4326
(This request uses the topp:states layer that comes with GeoServer installation)
I changed the coordinates of the bbox to "-119.5,39,-119,40 " to show this strange behaviour.
This “-119.5,39,-119,40” bbox is a small rectangle all in Nevada but close to California border.
The WFS request is then :
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=topp:states&propertyName=STATE_NAME,PERSONS&BBOX=-119.5,39,-119,40,EPSG:4326
This request returns Nevada and California. I can’t understand why California stands in the results although the bbox is fully in Nevada.
After a few investigations on the topp:states layer and other polygons and lines layers, it seems that the above WFS_getFeatureBBOX.url selects all feautures whose bounding boxes intersect the request bbox. For example, in the above example, the “-119.5,39,-119,40” bbox is fully outside California but it is inside California’s bounding box, so California is selected.
Is this the way the WFS_getFeatureBBOX.url works or is this a bug ?
And what WFS url request could select the shapes that only intersect a bbox, and not the shapes whose bounding boxes intersect a bbox ?
Thanks in advance
Blaise
Blaise PICINBONO
Ingénieur SIG
ALYOTECH TECHNOLOGIES
2, rue Antoine Becquerel
35700 RENNES
Tél. 02 23 21 11 11
Fax. 02.23.21.11.00
www.alyotech.fr
P N’imprimez ce mail que si c’est vraiment nécessaire____.
You are right, BBOX is searching for intersecting envelopes. It is faster and just OK when browsing around the map while doing some on-screen work. For accurate results use “intersects”.
This should be good enough, even not exact match:
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=query_benchmarks&rev=1236037547
-Jukka Rahkonen-
Lähettäjä: PICINBONO Blaise [mailto:blaise.picinbono@anonymised.com]
Lähetetty: 5. kesäkuuta 2009 12:21
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] strange getFeatureBBOX behaviour
Thanks in advance
Blaise
Blaise PICINBONO
Ingénieur SIG
35700 RENNES
Tél. 02 23 21 11 11
Fax. 02.23.21.11.00
www.alyotech.fr
