[Geoserver-users] strange polygons
Hello.
I have some depth areas in PostGIS with GeoServer 2.6.0 in front. The client is uDig.
This is how it looks when I connect from uDig to PostGIS directly or to GeoServer with WFS. This is correct.
http://dalsnuten.ecc.no/~halset/tmp/gs/wfs.png
This is how it looks when I connect from uDig to GeoServer with WMS. Some of the polygons are cut strangely. The cutting for some of them change when I zoom in/out.
http://dalsnuten.ecc.no/~halset/tmp/gs/wms.png
The SLD in use by the WMS uses a LineSymbolizer for the stroke and a PolygonSymbolizer for the fill.
          <LineSymbolizer>
            <Stroke>
              <CssParameter name="stroke”>#FF0000</CssParameter>
              <CssParameter name="stroke-width">1</CssParameter>
            </Stroke>
          </LineSymbolizer>
          <PolygonSymbolizer>
            <Fill>
              <CssParameter name="fill">#BBFFFF</CssParameter>
            </Fill>
          </PolygonSymbolizer>
Any tips to where I should start digging to get the WMS polygon more like (not talking colors here) the WFS polygons?
Tore Halset.
Hello.
Some users could not click on the URL. Probably problem with the ‘~’ letter.
This is how it should look. Drawn in uDig with data from GeoServer WFS.
http://bit.ly/1rKC51P
This is how it looks with GeoServer WMS. Some of the strange cutoffs change when I zoom in/out
http://bit.ly/1Ea1ECc
Any tips on where to look?
Tore Halset.
On 31 Oct 2014, at 14:21, Tore Halset <halset@anonymised.com> wrote:
Hello.
         <LineSymbolizer>
           <Stroke>
           </Stroke>
         </LineSymbolizer>
         <PolygonSymbolizer>
           <Fill>
           </Fill>
Tore Halset.
Geoserver-users mailing list
Hi Tore,
sounds like a bug in polygon clipping (we do that before rendering, as the part of
the polygon in the display can be a very small portion of the view, and besides
performance issues there are known bugs in java2d that would just take down
the JVM if we tried to render them).
Could you open a ticket at http://jira.codehaus.org/browse/GEOS with all
that’s required to reproduce the issue, that is, data, style and request?
On Fri, Oct 31, 2014 at 2:21 PM, Tore Halset <halset@anonymised.com> wrote:
Hello.
1
#BBFFFF
Tore Halset.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello.
Thank you Andrea. It turned out that it was all my fault. Again. Some of the *areas* was in fact LineStrings.. After removing all of the LineStrings, the WMS works just fine! Sorry for the noise!
Tore Halset.
On 01 Nov 2014, at 22:29, Tore Halset <halset@anonymised.com> wrote:
Hello.
Tore Halset.
Hello.
        <LineSymbolizer>
          <Stroke>
          </Stroke>
        </LineSymbolizer>
        <PolygonSymbolizer>
          <Fill>
          </Fill>
Tore Halset.
Hi Tore,
thanks for letting us know :slight_smile:
On Mon, Nov 3, 2014 at 3:21 PM, Tore Halset <halset@anonymised.com> wrote:
Hello.
Thank you Andrea. It turned out that it was all my fault. Again. Some of the areas was in fact LineStrings… After removing all of the LineStrings, the WMS works just fine! Sorry for the noise!
Tore Halset.
Hello.
Tore Halset.
Hello.
1
#BBFFFF
Tore Halset.
Ing. Andrea Aime
@geowolf
Technical Lead
