[Geoserver-users] Strange WCS behaviour
Hi All,
I’m using Geoserver to set up a WCS and I’m getting some strange results which, interestingly, don’t manifest through the WMS interface. It seems that the BBOX in the WCS request is being ignored because what ever the requested extents, the whole image as stored on the server is being returned. However, if I use the WMS interface with the same BBOX, the resulting image has the correct extents.
In case it helps, the two requests are here:
WCS http://81.29.77.204:8080/geoserver/wcs?SERVICE=WCS&REQUEST=GetCoverage&VERSION=1.0.0&CRS=EPSG:4326&BBOX=-7,45,5,60&FORMAT=GeoTIFF&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&WIDTH=350&HEIGHT=500&COVERAGE=MET8FC1410071145&Styles=raster
WMS http://81.29.77.204:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetMap&VERSION=1.1.1&SRS=EPSG:4326&BBOX=-7,45,5,60&FORMAT=image/png&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&WIDTH=350&HEIGHT=500&LAYERS=MET8FC1410071145&Styles=raster
Is there any reason why this might be happening? It’s quite possible I don’t fully understand the functionality of WCS’s. In case it matters, the SRS of the source GeoTIFF is EPSG:9804.
Any ideas would be very much welcome,
Andy
View this message in context: Strange WCS behaviour
