I was using GeoServer to display WFS data in uDig and it was working fine, then I changed the GeoServer port to 8081 instead of 8080 and now I’m getting some strange problems.
uDig finds my WFS layers fine, but when I try and load them it says there is a problem with the SRS. I’ve changed back to port 8080 now and it’s fine…
Any idea why this could be?
Jon
Hi Jon,
Strange indeed. Do you happen to have any error logs or stack traces from GeoServer or uDig?
-Justin
Britton J (AT) wrote:
I was using GeoServer to display WFS data in uDig and it was working fine, then I changed the GeoServer port to 8081 instead of 8080 and now I'm getting some strange problems.
uDig finds my WFS layers fine, but when I try and load them it says there is a problem with the SRS. I've changed back to port 8080 now and it's fine...
Jon
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can't happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
