On Thu, Mar 19, 2015 at 3:52 PM, Ville Jussila <vijussila@anonymised.com> wrote:
Hi there,
I have a problem with rendering my data with SLD through Geoserver. My
data is in PostGis database and I need to use rexep to match the values in
it. I have read few threads here and one of them dealt with the same
problem. Unfortunately that thread didn’t give me an answer.
I wrote in SLD:
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:And>
<ogc:Function name="strMatches">
<ogc:PropertyName>kohdenimi</ogc:PropertyName>
<ogc:Literal>_viiteviiva</ogc:Literal>
</ogc:Function>
<ogc:PropertyIsNotEqualTo>
<ogc:Literal>YJK_Sähkö_Helen_viiteviiva</ogc:Literal>
</ogc:PropertyIsNotEqualTo>
</ogc:And>
</ogc:Filter>
Can I use strMatches in PostGis database or does it work only for in
Oracle example?
No, there is no way to use general regular expression against databases,
strMatches uses
the Java regex syntax, we'd need someone to do the work required to write
the
sql encoder for it, and to turn the java regex syntax in the database one.
That said... it seems to me you have a pretty simple match over there,
can't it be
made also using PropertyIsLike, which is translated to a LIKE filter in sql?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
