[Geoserver-users] Style clipped ends of a LineString?
Good day, GeoServer!
I am doing some route visualization and had the idea of always showing the end points, no matter if they are actually visible or not. This might give the user additional info about the direction of the route, but the thing is, how to do it? 1 idea is to draw the end points at the clipped coordinates of the route line segments, in case they are getting clipped explicitly at all. Any way to achieve this? Also, additional ideas are welcome :slight_smile: Thank you and have a nice Sunday evening.
Mihail
Hi Mihail,
the correct answer probably depends on the way your route segments are available. Assuming you have them as a single LineString geometry where the end points are the first and last point of the LineString one way to show them would be to use the startPoint and/or endPoint functions inside a Geometry transformation.
An example here:
geometry circle #FF0000 12
Can you try to explain in more detail how you store your route line segments and what is the final result you expect?
Mauro Bartolomeoli
2013/9/29 Mihail Ivanchev <mihail12@anonymised.com>
Mihail
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
