Hi group,
I ran into a problem for the first time.
In publishing tab of a layer, the style preview icon is not showing (broken link icon instead) …
Anybody ran into this problem yet ?
Thanks
Hi group,
Thanks
Generally it means that GeoServer can’t create the legend as a result of GetLegend. It could be because of a number of reasons (i…e, it can’t find a file its reliant on for instance, or the SVG is invalid) - the console/error log will likely tell you. If not, up the error logging level to debugging and try again to get more detail in your error.
Jonathan
On 8 March 2013 16:05, Olivier Gagnon <mcnolii@anonymised.com> wrote:
Hi group,
Thanks
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-users mailing list
Geoserver-users@anonymised.comet
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
