I’m trying to render overlapping multiple lines, styling the layer with SLD in GeoServer but PerpendicularOffSet doesn’t work.
I have seen mails about a partial implementation [1] [2] of this feature, and we could be able to implement a solution to fix this problem, implementing a geometry transformation for example, but we need to know what is the state of this issue and if there are another different solution.
Regards!!!
[1] https://jira.codehaus.org/browse/GEOT-3912
[2] https://github.com/geotools/geotools/pull/1
