[Geoserver-users] styling KML
I'd like to affect icons to generated KML. I wrote a sld file :
<StyledLayerDescriptor version="1.0.0"
    xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
    xmlns="http://www.opengis.net/sld&quot;
    xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
  <NamedLayer>
    <Name>test</Name>
    <UserStyle>
      <Title>Skeleton</Title>
      <Abstract>A skeleton style</Abstract>
      <FeatureTypeStyle>
                 <Rule>
          <PointSymbolizer>
             <Graphic>
               <ExternalGraphic>
                  <OnlineResource xlink:type="simple"
xlink:href="http://maps.google.com/mapfiles/kml/pal3/icon55.png&quot;/&gt;
                  <Format>image/png</Format>
               </ExternalGraphic>
             </Graphic>
          </PointSymbolizer>
                  </Rule>
             </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
but when I lauch the service I get :
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt;
<ServiceExceptionReport version="1.1.1" > <ServiceException>
      java.lang.NullPointerException
null
</ServiceException></ServiceExceptionReport>
(it works with standard styles i.e. with no ExternalGraphic stuff)
Has anybody an idea ?
Laurent
View this message in context: http://www.nabble.com/styling-KML-tp19269673p19269673.html
Hi Laurent,
The full exception stack trace would help diagnose your problem. It should show up on the console or in the error log when you execute the request.
-Justin
LaurentPierre wrote:
<StyledLayerDescriptor version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd" xmlns="http://www.opengis.net/sld&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
  <NamedLayer>
    <Name>test</Name>
    <UserStyle>
      <FeatureTypeStyle>
                 <Rule>
          <PointSymbolizer>
             <Graphic>
               <ExternalGraphic>
               </ExternalGraphic>
             </Graphic>
          </PointSymbolizer>
                  </Rule>
             </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
null
Laurent
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
Somebody already had this problem with layers Muiti-Linestring in geoserver
02 Set 10:43:32 INFO [geoserver.filters] - Not compressing output for mimetype: image/png
02 Set 10:43:32 ERROR [geotools.rendering] - Could not create the next feature:IllegalAttribute: com.vividsolutions.jts.geom.MultiLineString , but got com.vi
vidsolutions.jts.geom.LineString
java.util.NoSuchElementException: Could not create the next feature:IllegalAttribute: com.vividsolutions.jts.geom.MultiLineString , but got com.vividsolution
at org.geotools.data.store.FeatureReaderIterator.next(FeatureReaderIterator.java:72)
at org.geoserver.feature.RetypingFeatureCollection$RetypingIterator.next(RetypingFeatureCollection.java:114)
.,._
Best regards,
Fernando Quadro
http://www.fernandoquadro.com.br
fsquadro@anonymised.com
Veja mapas e encontre as melhores rotas para fugir do trânsito com o Live Search Maps! Experimente já!
Hi Fernando,
Are you using Postgis? I have seen this problem occur when the geometry_columns entry for a table has a type of 'MULTILINESTRING', but actually contains just 'LINESTRING' geometries.
Assuming this is the problem in your case i suggest you update the geometry columns entry (if your data only contains LineString data), or change it to 'GEOMETRY' if you need to store geometries of different types.
-Justin
Fernando Quadro wrote:
02 Set 10:43:32 ERROR [geotools.rendering ] - Could not create the next feature:IllegalAttr ibute: com.vividsolutions. jts.geom. MultiLineString , but got com.vi
vidsolutions. jts.geom. LineString
java.util.NoSuchEle mentException: Could not create the next feature:IllegalAttr ibute: com.vividsolutions. jts.geom. MultiLineString , but got com.vividsolution
s.jts.geom.LineStri ng
        at org.geotools. data.store. FeatureReaderIte rator.next( FeatureReaderIte rator.java: 72)
        at org.geoserver. feature.Retyping FeatureCollectio n$RetypingIterat or.next(Retyping FeatureCollectio n.java:114)
__._,_.___
Best regards,
Fernando Quadro
fsquadro@anonymised.com <mailto:fsquadro@anonymised.com>
Veja mapas e encontre as melhores rotas para fugir do trânsito com o Live Search Maps! Experimente já! <http://www.livemaps.com.br/index.aspx?tr=true&gt;
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
http://opengeo.org
In fact the generated KML looks like :
<kml>
   <Document>
      <name>edfgeo:clientassoc</name>
      <Style id="GeoServerStyleclientassoc.1515">
         <IconStyle>
            <Icon/>
         </IconStyle>
         <Style id="GeoServerStyleclientassoc.5203">
            <IconStyle>
               <Icon/>
            </IconStyle>
            <Style id="GeoServerStyleclientassoc.6743">
               <IconStyle>
                  <Icon/>
               </IconStyle>
               <Style id="GeoServerStyleclientassoc.9349">
                  <IconStyle>
                     <Icon/>
                  </IconStyle>
with no information in it
strange no ?
Laurent
View this message in context: http://www.nabble.com/styling-KML-tp19269673p19271344.html
Hi Laurent,
This is happening because an error is occurring while trying to encode the feature, in particular the icon.
We need the java stack trace to determine what though. Search through the log for java.lang.NullPointerException and include the lines below it and we should be able to tell you what the problem is.
-Justin
<kml>
   <Document>
         <IconStyle>
            <Icon/>
         </IconStyle>
            <IconStyle>
               <Icon/>
            </IconStyle>
               <IconStyle>
                  <Icon/>
               </IconStyle>
                  <IconStyle>
                     <Icon/>
                  </IconStyle>
strange no ?
Laurent
Justin Deoliveira
http://opengeo.org
I checked the file server.log (Glassfish) but I couldn't find any error when
the service is called.
Justin Deoliveira-6 wrote:
Hi Laurent,
-Justin
<kml>
   <Document>
         <IconStyle>
            <Icon/>
         </IconStyle>
            <IconStyle>
               <Icon/>
            </IconStyle>
               <IconStyle>
                  <Icon/>
               </IconStyle>
                  <IconStyle>
                     <Icon/>
                  </IconStyle>
strange no ?
Laurent
Justin Deoliveira
http://opengeo.org
challenge
prizes
world
View this message in context: http://www.nabble.com/styling-KML-tp19269673p19273768.html
Hi Justin,
I eventally found that in my logs :
[#|2008-09-03T12:01:02.501+0200|INFO|sun-appserver9.1|javax.enterprise.system.stream.out|_ThreadID=20;_ThreadName=httpSSLWorkerThread-8080-3;|03
sept. 12:01:02 WARN [geoserver.kml] - Failure tranforming feature to
KML:clientassoc.55792
java.lang.IllegalArgumentException: L'argument "value" ne doit pas être nul.
  at
org.geotools.util.SoftValueHashMap.ensureNotNull(SoftValueHashMap.java:103)
  at org.geotools.util.SoftValueHashMap.put(SoftValueHashMap.java:226)
  at
org.geotools.renderer.style.SLDStyleFactory.createStyle(SLDStyleFactory.java:308)
  at
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encodeStyle(KMLVectorTransformer.java:414)
I join a bigger extract http://www.nabble.com/file/p19286467/geoserver.log
geoserver.log
Laurent
when the service is called.
Hi Laurent,
-Justin
<kml>
   <Document>
         <IconStyle>
            <Icon/>
         </IconStyle>
            <IconStyle>
               <Icon/>
            </IconStyle>
               <IconStyle>
                  <Icon/>
               </IconStyle>
                  <IconStyle>
                     <Icon/>
                  </IconStyle>
strange no ?
Laurent
Justin Deoliveira
http://opengeo.org
challenge
prizes
world
View this message in context: http://www.nabble.com/styling-KML-tp19269673p19286467.html
Hi Laurent,
Thanks for the log. It is still not exactly sure what is going on ... i assume a problem with the style you are using. Can you attach the SLD for the style you are using for that layer. Thanks.
-Justin
Hi Justin,
  at
  at
  at
geoserver.log
Laurent
Hi Laurent,
-Justin
<kml>
   <Document>
         <IconStyle>
            <Icon/>
         </IconStyle>
            <IconStyle>
               <Icon/>
            </IconStyle>
               <IconStyle>
                  <Icon/>
               </IconStyle>
                  <IconStyle>
                     <Icon/>
                  </IconStyle>
strange no ?
Laurent
Justin Deoliveira
http://opengeo.org
challenge
prizes
world
Justin Deoliveira
http://opengeo.org
Hi Justin,
Here's the style http://www.nabble.com/file/p19368709/test.sld test.sld .
The funniest thing is that it works with my Geoserver at home (1.6.2) but
doesn't at work (1.6.4).
Laurent
View this message in context: http://www.nabble.com/styling-KML-tp19269673p19368709.html
Hi Laurent,
Strange indeed. I checked out the style and it looks fine... It must be something in combination with the data you are using. Any information about the dataset, format, geometry type, etc... would be helpful.
-Justin
Hi Justin,
Here's the style http://www.nabble.com/file/p19368709/test.sld test.sld . The funniest thing is that it works with my Geoserver at home (1.6.2) but
Laurent
Justin Deoliveira
http://opengeo.org
Hi Justin,
I tried to apply the same style with 'tiger:poi' from the examples coming
with Geoserver and it didn't work either. I tried too, with 1.6.2, to
affect different icons depending on the value of an attribute with no
succes.
Will you be at FOSS4G ?
Laurent
Hi Laurent,
-Justin
Hi Justin,
Laurent
Justin Deoliveira
http://opengeo.org
challenge
prizes
world
View this message in context: http://www.nabble.com/styling-KML-tp19269673p19414889.html
Hi Justin,
succes.
Hmmm... i am not sure... running out of ideas. I just tried that style with the tiger:poi layer and the custom icon showed up. However... i noticed that some wierd stuff happened. The icon i specified I got in google earth does not match the icon i see when i access it directly in the browser... i am not sure if this is intended google earth behaviour or not.
I wonder if this might be a google earth issue? Out of curiosity which version are you using?
Yes, I will be. Will you be attending?
Laurent
Hi Laurent,
-Justin
Hi Justin,
Laurent
Justin Deoliveira
http://opengeo.org
challenge
prizes
world
Justin Deoliveira
http://opengeo.org
In fact I try to use it with openlayers but I looked in the KML file to
check.
Yes I will, we could discuss the problem then.
Laurent
View this message in context: http://www.nabble.com/styling-KML-tp19269673p19438338.html
