I have a layer with a linestring and point columns. I need to style a linestring with an attribute “prog” and an arrow (following line). In the same layer I have to render the point as well that is in a separate column with attribute “label_closer” and the_geom_closer geometry.
I followed suggestion from
http://docs.geoserver.org/stable/en/user/styling/sld-tipstricks/mixed-geometries.html
here is the result.
the label near the arrow is not the “prog” attribute (that is missing) but the label_closer that should be rendered on point instead. Attached the full sld.
thanks
multi.sld (5.62 KB)
Hi Antonio,
I think you should specify the geometry to use not only on LineSymbolizer and PointSymbolizer, but also on TextSymbolizer(s), to let GeoServer know where to put the label, which geometry to use as a center point.
Thanks.
2013/1/14 Antonio Parrotta <antonioparrotta@anonymised.com>
here is the result.
![Inline images 2]()
thanks
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. SALE $99.99 this month only – learn more at:
http://p.sf.net/sfu/learnmore_122412
Geoserver-users mailing list
Morning Mauro,
it worked as you suggested. Appreciate. I added a second point and now the “prog” attribute is not displayed over the arrow (linestring). Second question is that now it is really slow. With this mixed points styling it is really unusable, navigate/zooming takes 10-20 seconds the layer to be displayed. Is there anything I can do to improve performance?
Thanks
2013/1/14 Antonio Parrotta <antonioparrotta@anonymised.com84…>
here is the result.
thanks
I got it working with sld attachet but is has become really slow. Geoserver starts to make heavy use of HD with apparently no reason. If I remove both points styling it works speedy Would you please give me some hints? The layer is actualy a view on a postgres DB
Thanks
multi.sld (7.79 KB)
here is the result.
thanks
On Wed, Jan 16, 2013 at 9:29 PM, Antonio Parrotta <antonioparrotta@…84…> wrote:
The reason is likely that you’re trying to put into the map way too many labels, and GeoServer has to accumulate
all of them in memory in order to perform conflict resolution. Either that, or the database view is heavy and
PostgreSQL is strugglying getting the data out of the disk.
Labelling must always be accompained with some scale limitation to avoid having too many labels
end up on screen, or in the conflict resolution engine
See also:
http://demo.geo-solutions.it/share/foss4g2011/gs_steroids_sgiannec_foss4g2011.pdf
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello Andrea,
I tried to use scaledenominator but with few features (less than 100 ) it takes very long. I would investigate further but have no time right now, so I switched to use style in JS openlayers by implementing this solution
http://gis.stackexchange.com/questions/30901/label-in-the-middle-of-linestring-in-openlayers
thanks for the support
On 18 January 2013 08:55, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Jan 16, 2013 at 9:29 PM, Antonio Parrotta <antonioparrotta@anonymised.com> wrote:
See also:
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Jan 18, 2013 at 2:41 PM, Antonio Parrotta <antonioparrotta@…84…> wrote:
Hello Andrea,
Ok. For the future, it would be useful if you could open a jira with the sld used and a data
dump big enough to reproduce the problem
Ing. Andrea Aime
@geowolf
Technical Lead
Hello Andrea,
I switched to materialized views, well, it works like a charm. Thanks for your support.
On 18 January 2013 16:07, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Jan 18, 2013 at 2:41 PM, Antonio Parrotta <antonioparrotta@anonymised.com> wrote:
Hello Andrea,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi All,
I have a minor issue with styling a “followline” layer. I included rules reported below in the style and it works fine. The only problem I see is that in my layer tree I have three white icons for the followline layer. I suspect that these white icons are there because of the styling rules. How can I get rid of them?
thanks you all,
Antonio
the Rules:
trafdir
W
20000.0
the_geom
Lucida Sans
18
#FF0000
true
false
trafdir
A
20000.0
the_geom
Lucida Sans
18
#FF0000
true
false
trafdir
T
20000.0
the_geom
Lucida Sans
18
#a4bdc5
true
false
On 21 January 2013 22:45, Antonio Parrotta <antonioparrotta@anonymised.com> wrote:
Hello Andrea,
Hello Andrea,
Ing. Andrea Aime
@geowolf
Technical Lead
Yes, each rule produces a separate legend.
If the rule differ in only a few elements based on an attribute condition, you can “invert the logic”, and use a function to select the appropriate symbology value. The Recode transformation function is probably the most elegant way of doing this:
http://docs.geoserver.org/latest/en/user/styling/sld-tipstricks/transformation-func.html#recode
On Tue, Jan 29, 2013 at 6:55 AM, Antonio Parrotta <antonioparrotta@anonymised.com> wrote:
Hi All,
thanks you all,
Antonio
the Rules:
trafdir
W
20000.0
the_geom
Lucida Sans
18
#FF0000
true
false
trafdir
A
20000.0
the_geom
Lucida Sans
18
#FF0000
true
false
trafdir
T
20000.0
the_geom
Lucida Sans
18
#a4bdc5
true
false
Hello Andrea,
Hello Andrea,
Ing. Andrea Aime
@geowolf
Technical Lead
MVPs and experts. ON SALE this month only – learn more at:
http://p.sf.net/sfu/learnnow-d2d
Hello Martin,
that was exactly what I needed for, thanks a lot. It works!!
cheers
Hi All,
thanks you all,
Antonio
the Rules:
trafdir
W
20000.0
the_geom
Lucida Sans
18
#FF0000
true
false
trafdir
A
20000.0
the_geom
Lucida Sans
18
#FF0000
true
false
trafdir
T
20000.0
the_geom
Lucida Sans
18
#a4bdc5
true
false
Hello Andrea,
Hello Andrea,
Ing. Andrea Aime
@geowolf
Technical Lead
