22 Jan 11:32:13 ERROR [wicket.Session] - Exception when detaching/serializing page
java.lang.OutOfMemoryError: PermGen space
I'm still wondering why this happens in 2.2.x, while it never occurred in 2.1.x.
Ok, i've updated the community module on the 2.2.x and master (2.3.x) branches. I was wrong about having fixed the WicketNotSerializableException issue so that is resolved on 2.2.x as well. The build server seems to have a pretty deep backlog right now, so if you are able to build from sources it might be faster to pull the latest from git and rebuild. Either way, the packages will be available in the next set of nightlies.
David Winslow
OpenGeo - http://opengeo.org/
On Wed, Jan 16, 2013 at 10:39 AM, David Winslow <dwinslow@anonymised.com <mailto:dwinslow@anonymised.com>> wrote:
I've only tested dynamic coloring in the geocss library, not with
the GeoServer web interface. It should have been a drop-in
replacement (no API changes) but I guess you never know.
The WicketNotSerializableException looks like an issue I already
fixed. The geocss jar does not interact with Wicket at all so I
would not expect it to introduce this type of problem.
Permgen errors are pretty common in GeoServer - GeoServer uses
many class libraries and this leads to PermGen pressure. The CSS
module brings in a different parsing library and collections
framework from the ones used in GeoServer already so it is fairly
"heavy" in this regard. I generally set -XX:PermSize=256M when
running with the CSS module and I don't encounter PermGen issues.
But I don't manage any long-running GeoServer instances with the
CSS module enabled, so it's possible there is a problem that I
haven't noticed.
In short, it seems that mixing and matching jar files is not
working well here. I'll look into updating the GeoServer build so
that you can just use a nightly build of the community module instead.
David Winslow
On Wed, Jan 16, 2013 at 4:37 AM, Matthias Uden
<matthias.uden@anonymised.com
<mailto:matthias.uden@anonymised.com>> wrote:
Hi David,
in order to get the expression based dynamic coloring to work
I tried the custom .jar with both GeoServer versions (2.1.3
and 2.2.3) - unfortunately without success.
Here is what happens with several different configurations:
GS 2.1.3 + CSS Module 2.1.x w/ your custom geocss .jar:
The CSS Module doesn't seem to work properly with this
combination. I cannot even create a new CSS style in the
interface.
Once I try that, it gives me this exception:
org.apache.wicket.WicketRuntimeException: Method
onFormSubmitted of interface
org.apache.wicket.markup.html.form.IFormSubmitListener
targeted at component [MarkupContainer [Component id =
layer-selection]] threw an exception
Caused by: java.lang.reflect.InvocationTargetException
Caused by: java.lang.NoClassDefFoundError: scala/Serializable
Caused by: java.lang.ClassNotFoundException: scala.Serializable
GS 2.2.1 + "standard" CSS Module 2.2.x:
Once I click on the "CSS Demo" link in the web interface,
everything becomes very slow and in the console I keep getting
these errors:
I've found some other threads in the internet dealing with
this problem.
Of course I could give the tomcat more PermGen memory space,
but still I wonder why this is happening, since it wasn't a
problem at all in GS 2.1.3
GS 2.2.1 + CSS Module 2.2.x w/ your custom geocss .jar:
Also memory issues. Some more specific error messages I get
include:
ERROR [lang.Objects] - Error serializing object class
org.geoserver.community.css.web.CssDemoPage [object=[Page
class = org.geoserver.community.css.web.CssDemoPage, id = 4,
version = 0]]
org.apache.wicket.util.io.SerializableChecker$WicketNotSerializableException:
Unable to serialize class:
org.geoserver.config.GeoServerDataDirectory
So, apart from the dynamic color issue I seem to have some
serious problems with my freshly set up GeoServer 2.2.3 w/ CSS
Module...
Any hints on what could go wrong here are appreciated,
although I will have to put some more effort in getting a
working configuration once I find the time.
Btw, in which combination did you get the dynamic coloring to
work?
Thanks again for your continued help! Apart from this issue I
am very enthusiastic about the CSS Module.
Matthias
Am 15.01.2013 15:34, schrieb David Winslow:
The update hasn't been included for any GeoServer release yet
- I had hoped to get another feature or two in before
updating the builds. However, the geocss JAR that I linked
to should work in any GeoServer version (I think.) Here's
that link again for reference:
http://gridlock.opengeo.org:8080/hudson/view/geoscript/job/geoscript-scala/ws/geocss/target/scala-2.9.1/geocss_2.9.1-0.7.4.jar
When I do get around to updating the build I won't be
updating 2.1.x as it is no longer a supported version of
GeoServer. However, SLDs generated with 2.2.x and later
should continue to be compatible with earlier versions of
GeoServer.
David Winslow
On Tue, Jan 15, 2013 at 8:27 AM, Matthias Uden
Hi David / all,
I'm sorry to bother you again with the CSS Module dynamic
coloring issue.
I still can't use dynamic color attributes in my CSS. Is
it possible that it only works for GeoServer 2.2.x? I'm
still using 2.1.3 and it seems that the geocss .jar has
only been updated for 2.2.x
Is there a way to make it working for 2.1.x too?
Thanks for your time and advice,
Matthias
Am 11.12.2012 15:06, schrieb Matthias Uden:
Hi David,
sorry for the late reply. Thanks a lot for the quick fix!
I will definitely have a look at the sources myself
someday if I find
the time.. For now I can achieve most of the desired
styling with the
CSS module. Thanks for your good work.
Matthias
Am 07.12.2012 15:49, schrieb David Winslow:
You're right, the docs are incorrect wrt the MIME
information. I'll go
ahead and update them so they will be correct
after the next automated
rebuild.
I am indeed the only developer on the CSS module.
It's not under
frequent development but I do try to keep up with
bugs reported on this
mailing list (and the github issue list.)
Actually I resolved the
dynamic color bug last night. I haven't updated
the plugin in the
community build yet (maybe this weekend) but if
you want an early peak
you can just grab the JAR file from
and overwrite the one that you already installed.
David Winslow
On Fri, Dec 7, 2012 at 6:12 AM, Matthias Uden
<mailto:matthias.uden@anonymised.com>>> wrote:
David,
thanks a lot for the quick answer and
clarification!
I didn't know about the CSS property
"mark-mime", since it is not part
of the CSS Property Listing
(http://docs.geoserver.org/stable/en/user/community/css/properties.html).
This
at least fixed the Icon Media Type issue.
It's a pity that dynamic colors are not yet
supported. I suppose that
the CSS Module is currently not actively
developed anymore due to lack
of time. Are you the only developer?
Matthias
Am 06.12.2012 16:14, schrieb David Winslow:
> *Relative Paths for Icons
> *The short answer is, no, you can't make
it do that. The problem is
> that the CSS-SLD converter actually uses
GeoTools' SLD writing
code to
> generate the SLD files, and GeoTools' SLD
support is not symmetric (I
> mean it cannot write everything that it
can read.) Resolving
relative
> paths into absolute ones is a compromise
between the actually desired
> behavior and not supporting relative
paths at all. This could
probably
> be fixed at the GeoTools level, but I
haven't taken the time to
inquire
> into why this asymmetry was built in in
the first place.
> Why are relative paths a problem for you?
Maybe there is a workaround
> that could be used (for example, if it's
a problem with
relocating data
> directories, I could add a tool to
re-convert all CSS styles
which would
> re-resolve the paths.)
> Icon Media Types*
> The image type logic is not as
sophisticated as you might expect -
> things like dynamic symbolizers[1] make
it impossible to know the
media
> type for the image in general, so I just
threw my hands up and
made it
> literally 'image/jpeg' if you don't
specify. You can provide the
media
> type explicitly with the *fill-mime*,
*stroke-mime*, *mark-mime*, or
> *shield-mime* property. For example:
> fill: url(pattern.png);
> fill-mime: "image/png";
> I don't guess it would be too hard to
make the CSS-SLD converter
try to
> look up the icon and inspect it to
provide the default, but this
is not
> as big a priority to me as rendering
transformations. If you want to
> look into it let me know and I can give
you some pointers on
what's needed.
> *Dynamic Color*
> This is simply a bug (the color handling
is a bit more complex
than the
> label handling, to allow for rgb() color
syntax.) Again, this is
> probably easily fixable given the time to
work on it; I'd say even
> easier than smart defaults for the icon
mime-type property.
> If you'd like to file bugs against
GeoScript-Scala[2] I'll keep them
> up-to-date if and when I get around to
working on these problems.
> [1]:
http://blog.geoserver.org/2008/12/08/dynamic-symbolizers-part-1/
> [2]:
https://github.com/dwins/geoscript.scala/issues
> On Thu, Dec 6, 2012 at 7:53 AM, Matthias Uden
<mailto:matthias.uden@anonymised.com>>>> wrote:
> Hi all,
> I've recently discovered the CSS
module as an alternative to
SLD styling
> and I'm quite enthusiastic about it.
Still, I cannot accomplish
> everything I used to do with SLD
before...
> Here are two specific questions:
> 1) When specifying a custom icon for
a mark with url(...), is it
> possible to get a relative path in
the generated SLD instead
of an
> absolute one? Also, is there a
possibility to specify the
format of that
> image correctly? Currently, it is
always converted to jpeg,
even when I
> put in a png...
> Example:
> CSS:
> mark: url('icons/entry.png');
> SLD:
> <sld:ExternalGraphic>
> <sld:OnlineResource
xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:type="simple"
xlink:href="file:/home/muden/test_geoserver/wms/map/geoserver/test_geoserver/styles/icons/entry.png"/>
> <sld:Format>image/jpeg</sld:Format>
> </sld:ExternalGraphic>
> 2) Specifying an attributes value
dynamically using a column
of the
> underlying DB table works fine for
e.g. labels. However, it
doesn't work
> for colors.
> Example (working):
> CSS:
> label: [key];
> SLD:
> <sld:Label>
> <ogc:PropertyName>key</ogc:PropertyName>
> </sld:Label>
> Example (not working):
> CSS:
> fill: [color];
> SLD:
> <sld:Fill/>
> Any help is appreciated!
> Thanks in advance and all the best,
> Matthias
> LogMeIn Rescue: Anywhere, Anytime
Remote support for IT. Free
Trial
> Remotely access PCs and mobile
devices and provide instant
support
> Improve your efficiency, and focus on
delivering more
value-add services
> Discover what IT Professionals Know.
Rescue delivers
> http://p.sf.net/sfu/logmein_12329d2d
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
<mailto:Geoserver-users@lists.sourceforge.net>
<mailto:Geoserver-users@lists.sourceforge.net>>
<mailto:Geoserver-users@lists.sourceforge.net>>>
> LogMeIn Rescue: Anywhere, Anytime Remote
support for IT. Free Trial
> Remotely access PCs and mobile devices
and provide instant support
delivering more value-add
services
Rescue delivers
Remotely access PCs and mobile devices and
delivering more value-add services
Discover what IT Professionals Know. Rescue
delivers
LogMeIn Rescue: Anywhere, Anytime Remote support
for IT. Free Trial
Improve your efficiency, and focus on delivering
Discover what IT Professionals Know. Rescue delivers
LogMeIn Rescue: Anywhere, Anytime Remote support for
IT. Free Trial
Remotely access PCs and mobile devices and provide
instant support
Improve your efficiency, and focus on delivering more
value-add services
