[Geoserver-users] Supplying GetMap dimension value to a parameterized query
I’ve created a layer using a parameterized query as a database view. I see how I can pass in arguments for the parameters using viewparams=p1:v1;… in the GetMap request. However, I would like to pass a dimension value from the GetMap request into the view as the argument. Is there any way to do this without forcing the client to copy the dimension value into the viewparams query string parameter?
Tom
On Thu, Oct 29, 2015 at 11:26 PM, Ruff, Thomas <THOMAS.RUFF@anonymised.com> wrote:
I've created a layer using a parameterized query as a database view. I
viewparams=p1:v1;... in the GetMap request. However, I would like to pass
No, not possible (unless we change the code somehow)... but I doubt it can
be made to easily work
in general, as dimension values can be provided in a number of ways,
instant, multiple values, range,
values relative to a reference, I sort of have a hard time picturing a sql
query that can seamlessly
handle them all (yes, a stored procedure or a custom function could of
course, still, it would
have to duplicate quite a bit of GeoServer own code).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
