[Geoserver-users] supported crs in wfs getCapabilities
Hi list,
Are we suppose to see the list of supported(others) crs in a wfs getcapabilities request cause I don’t see any on my.
Thanks
I suspect it depends on the WFS version.For me:
1.0.0 doesn’t have any CRS’ at all listed in GetCapabiltiies.
1.1.0 and 2.0.0
Every layer has a and a ows:WGS84BoundingBox specified.
Although I only have one CRS for all of our data though.
Jonathan
On 12 July 2013 04:15, <Victor.Tey@…367…> wrote:
Hi list,
Thanks
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
This has been asked and answered in February http://www.mail-archive.com/geoserver-users@lists.sourceforge.net/msg12938.html
You do not see the list of supported projections because Geoserver does not create such. However, all projections supported by Geoserver do work in GetFeature is reprojection from source to target system is possible.
-Jukka Rahkonen-
Jonathan Moules wrote:
For me:
1.0.0 doesn't have any CRS' at all listed in GetCapabiltiies.
1.1.0 and 2.0.0
Every layer has a <DefaultSRS> and a <ows:WGS84BoundingBox> specified.
Jonathan
On 12 July 2013 04:15, <Victor.Tey@anonymised.com<mailto:Victor.Tey@anonymised.com>> wrote:
Hi list,
Thanks
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@anonymised.comrge.net>
On Fri, Jul 12, 2013 at 5:15 AM, <Victor.Tey@anonymised.com> wrote:
Hi list,****
The issue in WFS is that you have to list the supported projections on a
per feature type basis.
Clearly we cannot do like in WMS, we'd end up listing 5000 crs for every
feature type.
We'd need a list of crs to be advertised, either globally configured (like
the limited srs list in wms config)
or something specific to the layer
Both would require some work to be implemented
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
