varyag
September 25, 2007, 9:22am
1
Does Geoserver support SVG for symbology encoding?
<ExternalGraphic>
I want to use SVG here
<OnlineResource
xlink:href="file:///D:/work/PRJ_Library/Symbol/test/symbols/sym1.svg"/>
<Format>image/svg+xml</Format>
</ExternalGraphic>
View this message in context: http://www.nabble.com/SVG-for-symbology-encoding-tf4514346.html#a12875939
<ExternalGraphic>
<OnlineResource
Yes, it should support it, but it's not very well tested.
Do you have problems with it, any sample that we can use to check?
And oh, btw, which version of GeoServer are you using?
varyag
October 10, 2007, 3:20am
3
<StyledLayerDescriptor version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
xmlns="http://www.opengis.net/sld" ; xmlns:ogc="http://www.opengis.net/ogc" ;
xmlns:xlink="http://www.w3.org/1999/xlink" ;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> ;
<NamedLayer> <Name> poi </Name>
<UserStyle>
<FeatureTypeStyle>
<Rule>
<PointSymbolizer>
<Graphic>
<ExternalGraphic>
<OnlineResource
<Format>image/svg</Format>
</ExternalGraphic>
<Size>11</Size>
</Graphic>
</PointSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
this is a full definition SLD. I have problems with it. Geoserver 1.5.1.
View this message in context: http://www.nabble.com/SVG-for-symbology-encoding-tf4514346.html#a13128750
<StyledLayerDescriptor version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd" xmlns="http://www.opengis.net/sld" ; xmlns:ogc="http://www.opengis.net/ogc" ; xmlns:xlink="http://www.w3.org/1999/xlink" ; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> ;
<UserStyle>
<FeatureTypeStyle>
<Rule> <PointSymbolizer>
<Graphic>
<ExternalGraphic>
<OnlineResource
</ExternalGraphic>
<Size>11</Size>
</Graphic>
</PointSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
I believe you're experiencing http://jira.codehaus.org/browse/GEOS-1396 ,
but without more info I cannot be sure.
varyag
October 16, 2007, 2:37am
5
Thank you very much
View this message in context: http://www.nabble.com/SVG-for-symbology-encoding-tf4514346.html#a13225841
