[Geoserver-users] SVG Support in OpenLayers (Tiling,Caching)?
Hello everybody,
thanks a lot for this great piece of software! It is great and I am happy it exists.
At the moment I am trying do develop some kind of SVG based WMS-Client for the iPhone using the built-in tilt sensor for semi-automatic zooming while panning.
I am evaluating the possibility of using OpenLayers for navigation. Everything runs fine so far.
My Question now is:
1) Can I make OpenLayers request SVG as the format? In the drop down menu ,there are just raster formats such as PNG, JPEG and GIF.
2) If i can figure out how tu turn it on, would it be possible to use tiling? If yes, which TilingCache is recommended, TileCache or GeoWebCache.
3) Is the toolbox in the OpenLayers Demo Page added by Geoserver or this something that is provided by OpenLayers? I haven't seen it on any other MapService that uses OpenLayers.
I know, that I could also post some og these question in the OpenLayers - users list, but I thought I should try here first.
Thanks a lot.
Ivo
Deutsche Telekom Laboratories (Berlin)
(doing my diploma project there)
Ivo Brodien ha scritto:
Hello everybody,
My Question now is:
Well, OL uses SVG in firefox to render vector data, but afaik it
cannot deal with SVG as a data source. You should ask on the OpenLayers
ml thought, I'm no expert in OL.
None of them can cache SVG as far as I know.
GeoWebCache can do some KML caching, in a pyramid, each feature
is stored in just one tile (so that the geometry is not sliced),
but that caching atm is geared towards Google Earth super overlays.
Nope, I added it to show off some of the GeoServer extra capabilities.
It's not really rocket science, I'm no javascript developer (server
side guy).
Andrea Aime
OpenGeo - http://opengeo.org
thanks for the quick answer.
Hello everybody,
My Question now is:
ok, I will ask there.
I was afraid, that this would be the case. That is a pity since I think it is essential for the user experience that there is a cache for the SVG data.
I know, was just wondering.
Bye
Ivo
Hello everybody,
At the moment I am trying do develop some kind of SVG based WMS- Client for the iPhone using the built-in tilt sensor for semi- automatic zooming while panning.
My Question now is:
Well, I guess the sole caching in GWC would not be that difficult,
the real issue is avoiding the same feature to end up in two
separate tiles, and that requires some collaboration from the
SVG generator. That's something we do in KML superoverlay,
I guess it could be applied to SVG as well
(in the end we just build an appropriate filter for the current
tile), but I don't know how much time it would take. For sure it
would require some familarity with the SVG/GML generators code.
Andrea Aime
OpenLayers can load vector data from KML, so GWC could be used for this as-is. I don't know how much KML styling or tiling is supported though.
http://openlayers.org/dev/examples/kml-layer.html is an example of a static KML layer (the entire KML dataset is loaded on startup) so hopefully that will help you get started.
Hope this helps.
-David Winslow
Hello everybody,
My Question now is:
