[Geoserver-users] symbolic link to Geoserver deployment
I have been using symbolic links for controlling which Geoserver version I am using. (Linux, Tomcat) The problem is that recent versions can't be used that way. Does anyone know why? For example, I have working Geoserver deployments gs163 and gs174:
'ln -s gs163 geoserver1' works (http://host.domain/geoserver1/),
'ln -s gs174 geoserver2' doesn't (http://host.domain/geoserver2/), I get http 404 error
- mika -
Lehtonen, Mika ha scritto:
Can you elaborate? What is the link controlling? The geoserver under
tomcat, the data directory?
Never tried this actually.
Andrea Aime
OpenGeo - http://opengeo.org
yes, the geoserver under Tomcat. I explain shortly what I have usually done:
1) I download the latest stable Geoserver war distribution and unzip it.
2) I rename the geoserver.war with the name describing the version, like gs174.war
3) I move that war into Tomcat's directory where it will autodeploy. (I am using virtual host configuration in Tomcat so the new Geoserver can be accessed from http://subdomain.domain/gs174/)
4) After that I create a symbolic link into that very directory, for example geoserver, which points at the deployed geoserver (gs174). After that I can access the new geoserver version with a link: http://subdomain.domain/geoserver/
This has been an easy way to control different versions. I have applications which have http://subdomain.domain/geoserver/ hardcoded. Changing the gs version has been easy by changing the link. But for some reason, it doesn't work in 1.74 anymore. :frowning:
- mika -
Andrea Aime kirjoitti:
So,
anyone hasn’t got any clue if something has changed in Geoserver war so that deployed Geoserver can’t be reached through symbolic link any more?
  • mika -
Mika Lehtonen kirjoitti:
So,
anyone hasn't got any clue if something has changed in Geoserver war so that deployed Geoserver can't be reached through symbolic link any more?
I tried what you suggested, in the startup logs I've noticed this:
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is org.geowebcache.storage.StorageException: Database may be already in use: Locked by another process. Possible solutions: close all other connection(s); use the server mode [90020-104]
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
  at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
  ... 41 more
Caused by: org.geowebcache.storage.StorageException: Database may be already in use: Locked by another process. Possible solutions: close all other connection(s); use the server mode [90020-104]
  at org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend.<init>(JDBCMetaBackend.java:59)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
  ... 43 more
So I guess the problem is with GWC embedded tile database, it cannot be
opened twice. In your setup you basically have two GeoServer running
against the same data directory, and the startup in the second one
fails during startup trying to get a hold of the same db the first
one has already opened.
Arne, afaik a way was to remove the GWC jars from GeoServer?
Andrea Aime
So,
    ... 41 more
    ... 43 more
Yeah, so it actually looks like Tomcat is treating these as two distinct servlets, meaning your memory consumption (at least as far as permgen is concerned) will be double too.
Currently the only way to deal with that is to remove gwc*.jar and geowebcache*.jar from the WEB-INF/lib directory and restart.
-Arne
Arne Kepp
Ok,
thanks. So this has not been very clever, although I have found it to be extremely handy. Have to think of some other way..
- mika -
Arne Kepp kirjoitti:
So,
    ... 41 more
    ... 43 more
-Arne
Ok,
Tomcat "deploying" a war really just means unzipping the .war for it.
So I guess you can put your GeoServer in some folder other than webapps,
unzip it, create a symbolic link from webapps to the unzipped folder.
That should do the trick
Andrea Aime
Shrug, RAM is (contrary to popular belief) is cheap, people's time is not. I would just go for it if you dont need GWC.
I will make it possible to disable the metastore (and continue with a limited set of features) soon, it's implemented on trunk and in 1.1..1.
-Arne
Lehtonen, Mika wrote:
Ok,
- mika -
So,
    ... 41 more
    ... 43 more
-Arne
Arne Kepp
That's very true! But I am afraid I will be needing GWC, if not now, then in the near future. Actually I tried it and didn't get it working. So the reason is most probably this dublicated deployment. Have to test it without the link.
- mika -
BTW: Andrea, your approach doesn't seem to be bad at all either.
-Arne
Ok,
- mika -
So,
    ... 41 more
    ... 43 more
-Arne
In fact, it's a much better idea. We use symlinks on our servers too, but for the entire webapp directory.
-Arne
Arne Kepp
Works just fine.
Thanks. Best solutions are often too obvious.
- mika -
Ok,
