[Geoserver-users] Symlinks for data sub-directories?
Hi
We have been struggling to get GeoServer to follow data stored in a
symlinked directory (symlinked from GeoServer's actual data directory). All
permissions have been set and the owner/group is set to Tomcat7. The ls
output shows:
lrwxrwxrwx 1 tomcat7 tomcat7 21 Aug 4 13:03 spatial -> /mnt/sdi/spatial/
and this link and file system can be navigated from the command line.
If any of the data is copied over from the symlinked directory to the
actual data directory (in our case, at /var/geoserver/data/), then it can be
loaded as expected. If not, then we get an error message:
Error creating data store, check the parameters. Error message: Could not
acquire data access 'XYZ'
The log show the same message, along with the usual NullPointerException.
Is there an additional Tomcat or GeoServer configuration that is required to
access symlinked directories?
Thanks!
Derek
View this message in context: http://osgeo-org.1560.x6.nabble.com/Symlinks-for-data-sub-directories-tp5155119.html
Derek,
symlinks should work, but note that access depends on the permissions of the symlink target, not of the symlink itself.
What is the output of this?:
ls -al /mnt/sdi/spatial
If permissions are the problem, you can change the ownership and permissions of /mnt/sdi/spatial (*recursively*) with these commands, but note that this may not be what you want so use with caution:
chown -R tomcat7:tomcat7 /mnt/sdi/spatial
chmod -R ug+rX /mnt/sdi/spatial
Kind regards,
Ben.
On 05/08/14 21:14, Derek wrote:
Hi
output shows:
Thanks!
Derek
Infragistics Professional
Build stunning WinForms apps today!
Reboot your WinForms applications with our WinForms controls.
Build a bridge from your legacy apps to the future.
http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
Hi Ben
Thanks for the reply. Yes, the permissions look OK. Using your command, for example, ls -al /mnt/sdi/spatial/city/planning, I get this listing for a directory containing a shapefile that I am trying to access:
drwxrwxrwx 2 tomcat7 tomcat7 4096 Feb 26 09:37 .
drwxrwxrwx 7 tomcat7 tomcat7 4096 Aug 5 10:57 …
-rw-rwxrwx 1 tomcat7 tomcat7 47966 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.dbf
-rw-rwxrwx 1 tomcat7 tomcat7 145 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.prj
-rw-rwxrwx 1 tomcat7 tomcat7 1556 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.sbn
-rw-rwxrwx 1 tomcat7 tomcat7 196 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.sbx
-rw-rwxrwx 1 tomcat7 tomcat7 108300 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.shp
-rw-rwxrwx 1 tomcat7 tomcat7 1212 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.shx
Is there something else that needs to be changed?
Regards
Derek
On 6 August 2014 04:55, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Derek,
If permissions are the problem, you can change the ownership and permissions of /mnt/sdi/spatial (recursively) with these commands, but note that this may not be what you want so use with caution:
Kind regards,
Ben.
Hi
symlinked directory (symlinked from GeoServer’s actual data directory). All
output shows:
lrwxrwxrwx 1 tomcat7 tomcat7 21 Aug 4 13:03 spatial → /mnt/sdi/spatial/
acquire data access ‘XYZ’
Thanks!
Derek
Geoserver-users@anonymised.comsourceforge.net
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Derek,
can you show us the contents of the datastore.xml file in your data directory that defines this data store?
What platform are you using? CentOS / RedHat often have selinux enforcing; this additional security mechanism may prevent tomcat7 from accessing some files. If you have selinux security contexts, you can see them with:
ls -alZ /mnt/sdi/spatial
ls -alZ /mnt/sdi/spatial/city/planning
Is this a network mount? What sort of filesystem? ext4, VFAT, or NTFS? Try:
mount | grep /mnt/sdi
It would also be helpful if you have a stack trace from the geoserver logs when this error occurs. This may give us more detail about the underlying error.
Kind regards,
Ben.
On 06/08/14 15:26, Derek wrote:
Hi Ben
drwxrwxrwx 7 tomcat7 tomcat7 4096 Aug 5 10:57 ..
Regards
Derek
<mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    Derek,
    Kind regards,
    Ben.
        Hi
        directory). All
        The ls
        output shows:
        /mnt/sdi/spatial/
        line.
        to the
        then it can be
        Could not
        required to
        Thanks!
        Derek
        http://osgeo-org.1560.x6.__nabble.com/Symlinks-for-data-__sub-directories-tp5155119.html
        <http://osgeo-org.1560.x6.nabble.com/Symlinks-for-data-sub-directories-tp5155119.html&gt;
        ------------------------------__------------------------------__------------------
        http://pubads.g.doubleclick.__net/gampad/clk?id=153845071&__iu=/4140/ostg.clktrk
        <http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk&gt;
        _________________________________________________
        <mailto:Geoserver-users@lists.sourceforge.net>
        https://lists.sourceforge.net/__lists/listinfo/geoserver-users
        <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
    Software Engineer
Software Engineer
Hi Ben
The mount command looks like:
/dev/mapper/san on /mnt/sdi type ext4 (rw,noatime,stripe=2560,data=ordered)
(The network admin tells me this a SAN drive mounted directly to the server.)
The response from the “Z” parameter - we are running Ubuntu - looks like:
-rw-rwxrwx 1 tomcat7 tomcat7 ? 47966 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.dbf
-rw-rwxrwx 1 tomcat7 tomcat7 ? 145 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.prj
-rw-rwxrwx 1 tomcat7 tomcat7 ? 1556 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.sbn
-rw-rwxrwx 1 tomcat7 tomcat7 ? 196 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.sbx
-rw-rwxrwx 1 tomcat7 tomcat7 ? 108300 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.shp
-rw-rwxrwx 1 tomcat7 tomcat7 ? 1212 Feb 26 09:37 CoT_master_sbc_2010_poly_wgs84_1.shx
No datastore.xml has been created for this shapefile. Here’s an example from another one (but this from data already on the host, and not on the symlinked drive).
DataStoreInfoImpl-63f945a9:147a4d4b8b2:-7fff Pop Pop Shapefile true WorkspaceInfoImpl-10073beb:147a14d6b3c:-8000 ISO-8859-1 shapefile true false Etc/UTC true sdi true file:ne_10m_admin_0_countries/ne_10m_admin_0_countries.shp shape <__default>false
I attach the relevant portion of the error trace from catalina.out.
Thanks
Derek
catalina.txt (20.5 KB)
On 6 August 2014 09:52, Ben Caradoc-Davies <Ben.Caradoc-Davies@…367…> wrote:
Derek,
Kind regards,
Ben.
Hi Ben
Regards
Derek
mailto:[Ben.Caradoc-Davies@csiro.au](mailto:Ben.Caradoc-Davies@anonymised.com)> wrote:
Derek,
Kind regards,
Ben.
Hi
directory). All
The ls
output shows:
/mnt/sdi/spatial/
line.
to the
then it can be
Could not
required to
Thanks!
Derek
<http://osgeo-org.1560.x6.nabble.com/Symlinks-for-data-sub-directories-tp5155119.html>
<http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk>
mailto:[Geoserver-users@anonymised.comsourceforge.net](mailto:Geoserver-users@anonymised.comsts.sourceforge.net)
<https://lists.sourceforge.net/lists/listinfo/geoserver-users>
Software Engineer
Software Engineer
Derek,
selinux is not present and is not your problem.
I tested adding a shapefile using GeoServer 2.5.2, then moving the directory away, and substituting a symlink. The shapefile continued to work. As far as I can tell, you are doing everything right.
The user interface is a bit broken in my browser, but that is a separate issue. It was equally broken with and without the symlink. I had to manually edit the url.
Kind regards,
Ben.
On 06/08/14 19:37, Derek wrote:
Hi Ben
server.)
The response from the "Z" parameter - we are running Ubuntu - looks like:
No datastore.xml has been created for this shapefile. Here's an example
symlinked drive).
<dataStore>
   <id>DataStoreInfoImpl-63f945a9:147a4d4b8b2:-7fff</id>
   <name>Pop</name>
   <description>Pop</description>
   <type>Shapefile</type>
   <enabled>true</enabled>
   <workspace>
     <id>WorkspaceInfoImpl-10073beb:147a14d6b3c:-8000</id>
   </workspace>
   <connectionParameters>
     <entry key="charset">ISO-8859-1</entry>
     <entry key="filetype">shapefile</entry>
     <entry key="create spatial index">true</entry>
     <entry key="memory mapped buffer">false</entry>
     <entry key="timezone">Etc/UTC</entry>
     <entry key="enable spatial index">true</entry>
     <entry key="namespace">sdi</entry>
     <entry key="cache and reuse memory maps">true</entry>
     <entry
key="url">file:ne_10m_admin_0_countries/ne_10m_admin_0_countries.shp</entry>
     <entry key="fstype">shape</entry>
   </connectionParameters>
   <__default>false</__default>
</dataStore>
Thanks
Derek
On 6 August 2014 09:52, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com
    Derek,
    NTFS? Try:
    Kind regards,
    Ben.
        Hi Ben
        command, for example, ls -al /mnt/sdi/spatial/city/__planning, I
        get this
        to access:
        CoT_master_sbc_2010_poly___wgs84_1.dbf
        CoT_master_sbc_2010_poly___wgs84_1.prj
        CoT_master_sbc_2010_poly___wgs84_1.sbn
        CoT_master_sbc_2010_poly___wgs84_1.sbx
        CoT_master_sbc_2010_poly___wgs84_1.shp
        CoT_master_sbc_2010_poly___wgs84_1.shx
        Regards
        Derek
        <mailto:Ben.Caradoc-Davies@anonymised.com>>> wrote:
             Derek,
        ownership and
        commands,
        caution:
             Kind regards,
             Ben.
                 Hi
        stored in a
                 directory). All
        Tomcat7.
                 The ls
                 output shows:
                 /mnt/sdi/spatial/
        command
                 line.
        directory
                 to the
                 then it can be
        message:
                 Could not
                 required to
                 Thanks!
                 Derek
        http://osgeo-org.1560.x6.__nab__ble.com/Symlinks-for-data-____sub-directories-tp5155119.html
        <http://nabble.com/Symlinks-for-data-__sub-directories-tp5155119.html&gt;
        <http://osgeo-org.1560.x6.__nabble.com/Symlinks-for-data-__sub-directories-tp5155119.html
        <http://osgeo-org.1560.x6.nabble.com/Symlinks-for-data-sub-directories-tp5155119.html&gt;\_\_&gt;
        Nabble.com.
        ------------------------------____----------------------------__--__------------------
        controls.
        http://pubads.g.doubleclick.____net/gampad/clk?id=153845071&____iu=/4140/ostg.clktrk
        <http://pubads.g.doubleclick.__net/gampad/clk?id=153845071&__iu=/4140/ostg.clktrk
        <http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk&gt;&gt;
                 ___________________________________________________
        <http://sourceforge.net>
                 <mailto:Geoserver-users@anonymised.com
        <mailto:Geoserver-users@lists.sourceforge.net>>
        https://lists.sourceforge.net/____lists/listinfo/geoserver-__users
        <https://lists.sourceforge.net/__lists/listinfo/geoserver-users&gt;
        <https://lists.sourceforge.__net/lists/listinfo/geoserver-__users <https://lists.sourceforge.net/lists/listinfo/geoserver\-users&gt;&gt;
             Software Engineer
    Software Engineer
Software Engineer
Hi Ben
Thanks for testing on your side as well. I am a bit stuck here, as moving a large volume of data files across to a machine not meant to store them does not seem like a good option. It also means that we cannot use one GeoServer instance to “point” to multiple locations unless we can get symlinks to work.
Any other ideas or tests I can run?
Thanks
Derek
On 7 August 2014 08:19, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Derek,
Kind regards,
Ben.
Hi Ben
server.)
symlinked drive).
Thanks
Derek
Derek,
NTFS? Try:
Kind regards,
Ben.
Hi Ben
get this
to access:
Regards
Derek
<mailto:Ben.Caradoc-Davies@__csiro.au
mailto:[Ben.Caradoc-Davies@csiro.au](mailto:Ben.Caradoc-Davies@anonymised.com)>> wrote:
Derek,
ownership and
commands,
caution:
Kind regards,
Ben.
Hi
stored in a
directory). All
Tomcat7.
The ls
output shows:
/mnt/sdi/spatial/
command
line.
directory
to the
then it can be
message:
Could not
required to
Thanks!
Derek
<http://nabble.com/Symlinks-for-data-__sub-directories-tp5155119.html>
<http://osgeo-org.1560.x6.nabble.com/Symlinks-for-data-__sub-directories-tp5155119.html
Nabble.com.
------------------------------____----------------------------------------------
controls.
<http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk>>
Geoserver-users@anonymised.comsource__forge.net
<mailto:Geoserver-users@anonymised.com__sourceforge.net
mailto:[Geoserver-users@anonymised.comsourceforge.net](mailto:Geoserver-users@anonymised.comsts.sourceforge.net)>
<https://lists.sourceforge.net/__lists/listinfo/geoserver-users>
<https://lists.sourceforge.__net/lists/listinfo/geoserver-__users <https://lists.sourceforge.net/lists/listinfo/geoserver-users>>
Software Engineer
Software Engineer
Software Engineer
On Thu, Aug 7, 2014 at 8:36 AM, Derek <gamesbook@anonymised.com> wrote:
Hi Ben
GeoServer instance to "point" to multiple locations unless we can get
symlinks to work.
Have you tried avoid using the symliks? GeoServer can access any full path
you're giving to it, what if you point directly to the files?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea
That works! Its less user-friendly, as the user now has to navigate “by hand” to the correct place, but it does work and so we will use this way for now.
I am still curious as to why the symlink method does not work; given that the target data and directories are accessible by this route.
Derek
Hi Ben
you’re giving to it, what if you point directly to the files?
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Aug 8, 2014 at 8:25 AM, Derek <gamesbook@anonymised.com> wrote:
Thanks Andrea
That works! Its less user-friendly, as the user now has to navigate "by
hand" to the correct place, but it does work and so we will use this way
for now.
Good to hear
Hum... don't know, Ben tried on his machine and it worked. Must be
something specific to your environment, which means we'd
need some developer debugging though the code (possibly the JDK own code)
to figure it out
Ing. Andrea Aime
@geowolf
Technical Lead
