On Thu, Apr 3, 2014 at 11:46 AM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
I was reading this two years old discussion
https://www.mail-archive.com/geoserver-users@lists.sourceforge.net/msg08781.html
There seems to be a GeoServer WMS vendor parameter "tiled=yes" and then
there is a GeoWebCache WMS vendor parameter "tiled=true"
http://docs.geoserver.org/stable/en/user/services/wms/vendor.html#tiled
Can anybody tell clearly what is the difference? What happens with
combinations "GS + tiled=true" and "GWC + tiled=yes"? And what is the role
of "tilesorigin" in this play?
As far as I know the parameters have an effect only on GeoServer, if you're
hitting GWC own WMS the requests will be tiled anyways.
For GeoServer tiled=true tells GeoServer to build a 3x3 metatile in memory,
and cache the 9 resulting tiles
in memory for a short time, under the assumptions the nearby tiles will be
fetched very soon.
Since GeoServer does not have a reference tile grid to use, the tilesorigin
parameter was used to give it
and origin point for the tile grid.
When using the GWC direct integration, that tries to server map requests
aligning to the GWC cached grid directly,
without having GS paint the request, the integration will also trigger only
if tiled=true is present in the request
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
