[Geoserver-users] template
Hallo,
how can I change the output style of a getfeatureinfo query? Is it possible?
Thank you!
View this message in context: http://www.nabble.com/template-tf3787454.html#a10710880
kutte ha scritto:
Hallo,
At the moment, you can't, all the templating stuff is still on Geoserver trunk (to become Geoserver 1.6.0), and GetFeatureInfo output, in particular, is still not templated, not even in trunk (thought it would
be trivial to add the templating code for it).
In fact, it's a very old issue: http://jira.codehaus.org/browse/GEOS-196
I've scheduled this for 1.5.2, since I'm not sure we can make it for 1.5.1.
I'd suggest you register yourself as a watcher of that issue, so that
you can track its evolution. Or, if you're into coding, we can give you
directions on how to cook a patch for this.
