[Geoserver-users] Test execution order: random or fixed?
recently I noticed several people having issues with test failures in GeoServer
that cannot be reproduces on the build server, or, for what it’s worth, on some
devs machines.
Now, barring the usual windows/linux differences, some failures are caused by:
  • our base test classes not cleaning up the catalog/config after each test (to save execution time)
  • having some tests that change the configuration forgetting to add the corresponding
    @Before/@After methods to revert the change
  • the test method execution order changing based on the platform and JDK version
My first attempt at addressing this has been to try and create a fully randomize test
execution environment, where both test class and test method execution order is random:
https://github.com/aaime/geoserver/commit/982df40103ea21ea45e35cd41c23a6bb4f614b90
The idea was to continue working on it so that the runner stores the order of the last
failed run on the file system, and reproduces it until the test gets fixed.
Now, this path would lead us eventually to full test correctness vs execution order.
The downside is that making commits would be harder, a test that worked on your machine
for three times in a row might not work on the build server… and this is painful.
Another alternative is to go for fully fixed order (both predictable execution order for test classes,
and methods within the classes). Which is something that we get, too.
All we need is to upgrade to JUnit to 4.11. This version has a FixMethodOrder annotation, which
can be used to force an alphabetical ordering.
Unfortunately, using it is going be painful… since FixMethodOrder is not inherited by subclasses,
the jUnit people have a pull request and they are still discussing it:
https://github.com/junit-team/junit/pull/633
However, there is an upside: the annotation is not really needed.
When no method order is specified, JUnit 4.11 uses the “default” method sorter, which compares
the hash codes of the method names: this gives a weird (if you want), but predictable method
execution order.
Here is a patch for to get predictable execution order (it also forces maven to run test classes
in alphabetical order, for total control over the overall order)
https://github.com/aaime/geoserver/commit/2f4b420bbb5365236df6d74eb91c3a8b93b98888
Now, which one is better?
From a theoretical standpoint the fully randomized test approach is better, as it leads us towards
tests that have no unexpected dependencies on execution order.
However, the cost of that approach is high in terms of development and maintenance, since
the tests can fail unpredictably after the commit.
Given that it’s already hard to get any test at all, especially in pull requests, aggravating the
matter does not seem like the best move.
Being practical, I’d prefer to go for the fully predictable approach instead, and spend the extra
time saved from fixing the tests to fix actual bugs in GeoServer.
Unfortunately… jUnit is not ready yet.
Of course, you might have guessed it already, the two solutions have one thing in common:
either way, the build will fail after applying the patches, showing that we do indeed have tests
with execution order assumptions.
I’ve been trying to fix the tests with the fully fixed order, and it has been nice to find
that I get the same errors exactly in maven and in the IDE, and that the errors are reproducible
in JDK 6 and JDK 7 the same way (well, those that do not depend on some specific library
change in the Java API, that is).
Here is a sample patch that fixes the main module to build under the JUnit 4.11 predictable test
order (the security tests seem like a nightmare to cleanup in @After/@Before, so I just
made them run the full setup every time, improvements welcomed):
https://github.com/aaime/geoserver/commit/0452891ffbbe0d157d54fc5e0ade7dcdbb29c4cf
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Sat, Mar 9, 2013 at 9:01 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
devs machines.
Doh sorry, this mail was intended for the geoserver-devel mailing list.
However, if you are making pull requests to GeoServer, or plan to contribute code
in any ways, please chime in.
Ing. Andrea Aime
@geowolf
Technical Lead
I agree that while using random order to help enforce no assumptions about execution order would be great, in the end it would be too much overhead. So +1 on the fixed order approach.
Regarding the security tests i agree they are quite complicated, unfortunately they are also among the most costly tests to run and I fear moving large chunks of them back to repeated test setup moves us back toward slower build times which we all worked so hard in Vienna to improve.
Perhaps Christian can help out and spend some time updating the before/after hooks to work with the new execution order?
On Sat, Mar 9, 2013 at 1:03 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
devs machines.
Ing. Andrea Aime
@geowolf
Technical Lead
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
A Jira issue about the security tests would be nice, at the the moment I try to put my focus on bug fixing / documentation.
2013/3/11 Justin Deoliveira <jdeolive@anonymised.com>
On Sat, Mar 9, 2013 at 9:01 PM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
devs machines.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
On Tue, Mar 12, 2013 at 12:00 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Cool moved on with fixed order tests and committed the changes.
The OpenJDK build server is happy, the Windows one managed to move a few modules further (now it complains
about UTF-8 encoding in some wms tests, before it was failing right in “main”).
To compensate for the 2 security tests that I had to put in “repeat” mode I removed the repeat mode
from 6 other tests (a mix of wms, wfs, rest config and main module tests), getting overall
an improvement in build times on my machine of around 10 seconds.
I believe this is worth backporting to the 2.3.x series, what do you think?
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, Mar 17, 2013 at 10:40 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
And oh, created a jira about security tests with repeated setups:
http://jira.codehaus.org/browse/GEOS-5716
Ing. Andrea Aime
@geowolf
Technical Lead
