Hi Brent,
Thanks for the tip, exactly what I needed!
It is there in the ogc
"02-070_Styled_Layer_Descriptor_Implementation_Specification.pdf" but I
missed it.
Thanks
Rkgeorge
-----Original Message-----
From: Brent Owens [mailto:brentowens@anonymised.com]
Sent: Wednesday, November 15, 2006 2:04 PM
To: Randy George
Subject: Re: [Geoserver-users] text-align for SLD text symbolizer
Hi Randy,
You can use the Anchor point as part of the text symbolizer. Here is an
example:
<LabelPlacement>
<PointPlacement>
<AnchorPoint>
<AnchorPointX>0</AnchorPointX>
<AnchorPointY>0.5</AnchorPointY>
</AnchorPoint>
The numbers here mean that 0 (zero) is the left hand side of the label
and 0.5 is the middle height of the label. The numbers range from 0 to
1, but you can go out of the bounds I think to really offset the text.
These numbers are the percentage length and height of the label.
So if you use 0.5 and 0.5 for the X and Y anchor points, the middle of
the label will be located on the point (50% of the length, 50% of the
height).
Displacement is in pixels and will offset the label by the amount you
specify.
Brent Owens
(The Open Planning Project)
Randy George wrote:
I would like to center a label placement relative a geometry point
location the textsymbolizer part of my sld. It doesn't seem possible
to use something like css:text-align=center. Is there a way to achieve
the same thing using displacement or anchorpoint? I don't see how to
calculate a label length for a relative displacement? The default
placement seems to be css:text-align=left
<LabelPlacement>
<PointPlacement>
<Displacement>
<DisplacementX>-10</DisplacementX>
<DisplacementY>0</DisplacementY>
</Displacement>
</PointPlacement>
</LabelPlacement>
Thanks
Rkgeorge
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
