[Geoserver-users] text objects are vector in wms pdf output
the text objects in pdf-output from Geoserver wms are vector, not string. Is
this by purpose? Is there any ways or any chance to change this?
It also seems, that lowercase l-letter ( L ) is somewhat thicker than other
letters, see
https://drive.google.com/file/d/0B-5GTVFPLqxUc18tNnZJWS15eGc/view?usp=sharing
best regards,
Jakob
View this message in context: http://osgeo-org.1560.x6.nabble.com/text-objects-are-vector-in-wms-pdf-output-tp5220397.html
I am going to assume this is WMS PDF output, rather than use of the printing module. I wonder if the use of halo is forcing the conversion of the text to a shape?
Do you want to try turning the halo off and seeing if the text is retained as text (very hand for searching PDF content).
On 20 August 2015 at 00:09, Jakob Ventin <jventin@anonymised.com> wrote:
letters, see
best regards,
Jakob
Geoserver-users mailing list
Jody Garnett
On Wed, Aug 26, 2015 at 7:49 AM, Jody Garnett <jody.garnett@anonymised.com>
That's not the case, but you're close. All labels are turned to shapes
(glyphs) and painted as such,
this is to ensure uniformity within all label types (curved for example)
and to ensure centering with
the halo, which was off back when we used drawString instead (which was
several years ago,
I'd say 8-9)
Long story short, there is no way to paint labels as text in the current
code, and it's also not immediate
to get it back, the layouting engine breaks the string at the very
beginning to handle inline newlines,
autowrap, multiple scripts and the like.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
