[Geoserver-users] TextSymbolizer with multi line Label and Graphic
All,
I am trying to create a label that consists of some text with a rectangular border around it. I currently have a TextSymbolizer with a Label and a Graphic using the WellKnownName "square". This gets the desired result for a single line of text but if the text contains multiple lines the square graphic is not placed correctly.
I am reading from a PostgreSQL table that contains the text with new lines. I can also get the same result by using a single line and adding a very small autoWrap to create multi-line text. Here is an example of the text I am inserting:
UDPATE my_table SET label=E'First line\nSecond line\nThird line';
This thread is similar but I think was created before this was implemented at all:
http://osgeo-org.1560.x6.nabble.com/SLD-Graphic-inside-TextSymbolizer-Relative-placements-td4992671.html
After playing with all the SLD options I believe this is a bug and I am beginning to look through the GS/GT code. Has anyone seen this before? If not, can someone point me to the classes I should be looking at?
I'm using PostgreSQL 9.0 with PostGIS 1.5.2 and tried both GeoServer 2.2.4 and 2.4.4. Attached is my SLD and images of a single line and multi line text. I'm using a point geometry that is located in the middle of the text in both images.
Michael Romero
Software Engineer
Forward Slope, Inc.
619-780-0175
maw_publications.sld (2.17 KB)
On Tue, Mar 11, 2014 at 11:06 PM, Michael Romero
<mromero@anonymised.com>wrote:
All,
at all:
in both images.
Yes, I believe this might be a bug. The class you should be looking into is
this one:
https://github.com/geotools/geotools/blob/master/modules/library/render/src/main/java/org/geotools/renderer/label/LabelPainter.java
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea. I fixed the bug and created a pull request (https://github.com/geotools/geotools/pull/407). However, there are two potential issues:
1.) I don’t have a signed contribution license. It’s only 4 lines of code so this may not be necessary.
2.) I didn’t include a unit test. I’m having trouble getting the tests to pass on master, even before my changes. I’m getting an ArrayIndexOutOfBoundsException from line 173 of SLDStyleFactoryTest.java. The variable coordsExpected (and coords) is a double array of size 2 and the Javadocs for the currentSegment method (line 173) says it needs an array size 6, hence the exception. If I change the initialization to create an array of size 6 the test passes. I’m not sure how this test is passing for other developers and on the CI server. I tried Java 6 & 7.
Michael
On 03/12/2014 04:02 AM, Andrea Aime wrote:
On Tue, Mar 11, 2014 at 11:06 PM, Michael Romero <mromero@anonymised.com> wrote:
All,
I am trying to create a label that consists of some text with a rectangular border around it. I currently have a TextSymbolizer with a Label and a Graphic using the WellKnownName “square”. This gets the desired result for a single line of text but if the text contains multiple lines the square graphic is not placed correctly.
UDPATE my_table SET label=E’First line\nSecond line\nThird line’;
I’m using PostgreSQL 9.0 with PostGIS 1.5.2 and tried both GeoServer 2.2.4 and 2.4.4. Attached is my SLD and images of a single line and multi line text. I’m using a point geometry that is located in the middle of the text in both images.
Yes, I believe this might be a bug. The class you should be looking into is this one:
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Apr 1, 2014 at 12:22 AM, Michael Romero <mromero@anonymised.com>wrote:
potential issues:
1.) I don't have a signed contribution license. It's only 4 lines of
2.) I didn't include a unit test. I'm having trouble getting the tests
to pass on master, even before my changes. I'm getting an
create an array of size 6 the test passes. I'm not sure how this test is
Thanks for the patch. For 4 lines indeed the contributor agreement is not
required, but a test will be, I'll see if I can write on in spare time.
Which OS are you on? OSX? I hear the are problems running rendering tests
on that platform as the Apple JVM comes with some
native libs that are OSX specific.
Ing. Andrea Aime
@geowolf
Technical Lead
I do most of my development on OSX but was getting a variety of different errors running the tests so I switched to Ubuntu 12.04. After installing perceptualdiff in Ubuntu, the test failure below was the only one (in the render module).
Michael
On Tue, Apr 1, 2014 at 12:22 AM, Michael Romero <mromero@anonymised.com> wrote:
Thanks for the patch. For 4 lines indeed the contributor agreement is not required, but a test will be, I’ll see if I can write on in spare time.
Which OS are you on? OSX? I hear the are problems running rendering tests on that platform as the Apple JVM comes with some
Ing. Andrea Aime
@geowolf
Technical Lead
