On Tue, Sep 1, 2015 at 3:09 PM, walter.nordmann <walter.nordmann@anonymised.com>
wrote:
Hi, in my tiles some textsymbolizers are missing. Always when they are very
near the border of the tile.
i played around with buffer from 5 to 50 but nothing changed. If i switch
to
a point-style, i can see those adresses as dots. so it is no data error.
https://osm.wno-edv-service.de/geoserver/wms?SERVICE=WMS&REQUEST=GetMap&VERSION=1.1.1&LAYERS=osm%3Aadressen&STYLES=&FORMAT=image%2Fpng8&TRANSPARENT=true&HEIGHT=256&WIDTH=256&BUFFER=12&TIMEOUT=300&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A3857&BBOX=901651.185651939,6465196.726416778,901804.0597085094,6465349.600473348
the upper left one and one on the very right border are missing, if i
switch
to TextSymbolizer.
Any hints?
Search the archives, the topic has been discussed many times over the years.
The short answer is, we don't draw them because there is no guarantee the
other half of the label
will show up in the nearby tile, due to conflict resolution.
If you are happy risking to have cut labels, or can ensure there won't be,
you can use the "partials"
vendor option (I believe you need 2.7.x for that one):
http://docs.geoserver.org/stable/en/user/styling/sld-reference/labeling.html#partials
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
