Hi List,
Looking through my logs, in my tomcat6-stdout I’m seeing quite a few of these:
***** CSSEngine: exception property.syntax.error:org.w3c.dom.DOMException: The “fill” property does not support function values.
AttrValue:param(fill) #FFF
Exception:org.w3c.dom.DOMException
at org.apache.batik.css.engine.value.AbstractValueFactory.createInvalidLexicalUnitDOMException(AbstractValueFactory.java:60)
at org.apache.batik.css.engine.value.IdentifierManager.createValue(IdentifierManager.java:53)
at org.apache.batik.css.engine.value.AbstractColorManager.createValue(AbstractColorManager.java:187)
at org.apache.batik.css.engine.value.svg.SVGColorManager.createValue(SVGColorManager.java:123)
at org.apache.batik.css.engine.value.svg.SVGPaintManager.createValue(SVGPaintManager.java:101)
***** CSSEngine: exception property.syntax.error:org.w3c.dom.DOMException: The “stroke-width” property does not support function values.
AttrValue:param(outline-width) 1
at org.apache.batik.css.engine.value.LengthManager.createValue(LengthManager.java:94)
at org.apache.batik.css.engine.value.svg.StrokeWidthManager.createValue(StrokeWidthManager.java:89)
I’ve gone through all of my styles (they’re all SLD’s - not CSS styles at all) and none of them are using a within a fill or stroke or stroke-width.
Why I am getting these exceptions and what do they mean?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
dumb question: Are you sure the requests are your own requests and not sent
by somebody else who has his /her own styling without telling you? Is this
server open to the public?
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department Environment and Primary Industries
Level13, Marland House, 570 Bourke Street
Melbourne 3000
However this is on the internal system, no public access. I doubt QGIS Desktop, ArcView or MapInfo would be using SLD’s, and those are the only non-curated systems that are likely to have been used with this.
Unfortunately the items don’t include timestamps so I can’t look at the corresponding request.
Also - shouldn’t these errors be in the GeoServer log rather than stdout?
Christian
Dr Christian Maul
Project Manager
Melbourne 3000
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds. http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
The "fill" property does not support function values.
org.w3c.dom.DOMException: The "fill" property does not support function
values.
at
at
at
at
at
property.syntax.error:org.w3c.dom.DOMException: The "stroke-width" property
org.w3c.dom.DOMException: The "stroke-width" property does not support
The "stroke-width" property does not support function values.
function values.
at
at
at
This stack traces include Batik, so they are happening either as we write
out SVG, or as we are reading a SVG to be used as an icon.
Impossible to say which one of the two without the full stack trace
/instance1/tomcat6instance1-stdout.2014-01-29.log
A complete stacktrace:
at org.apache.batik.css.engine.CSSEngine$1.property(CSSEngine.java:744)
at org.apache.batik.css.engine.CSSEngine.getCascadedStyleMap(CSSEngine.java:768)
at org.apache.batik.css.engine.CSSEngine.getComputedStyle(CSSEngine.java:876)
at org.apache.batik.bridge.CSSUtilities.getComputedStyle(CSSUtilities.java:82)
at org.apache.batik.bridge.CSSUtilities.convertDisplay(CSSUtilities.java:564)
at org.apache.batik.bridge.GVTBuilder.buildGraphicsNode(GVTBuilder.java:206)
at org.apache.batik.bridge.GVTBuilder.buildComposite(GVTBuilder.java:171)
at org.apache.batik.bridge.GVTBuilder.build(GVTBuilder.java:82)
at org.geotools.renderer.style.SVGGraphicFactory$RenderableSVG.getGraphicNode(SVGGraphicFactory.java:211)
at org.geotools.renderer.style.SVGGraphicFactory$RenderableSVG.(SVGGraphicFactory.java:150)
at org.geotools.renderer.style.SVGGraphicFactory.getIcon(SVGGraphicFactory.java:95)
at org.geotools.renderer.lite.MetaBufferEstimator.visit(MetaBufferEstimator.java:307)
at org.geotools.styling.GraphicImpl.accept(GraphicImpl.java:354)
at org.geotools.renderer.lite.MetaBufferEstimator.visit(MetaBufferEstimator.java:236)
at org.geotools.styling.PointSymbolizerImpl.accept(PointSymbolizerImpl.java:93)
at org.geotools.renderer.lite.MetaBufferEstimator.visit(MetaBufferEstimator.java:140)
at org.geotools.renderer.lite.StreamingRenderer.findRenderingBuffer(StreamingRenderer.java:1477)
at org.geotools.renderer.lite.StreamingRenderer.getStyleQuery(StreamingRenderer.java:1013)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2009)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:837)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:481)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:521)
at org.geoserver.wms.GetMap.run(GetMap.java:253)
at org.geoserver.wms.GetMap.run(GetMap.java:124)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:73)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy61.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:87)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:615)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.ajp.AjpAprProcessor.process(AjpAprProcessor.java:448)
at org.apache.coyote.ajp.AjpAprProtocol$AjpConnectionHandler.process(AjpAprProtocol.java:403)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1703)
at java.lang.Thread.run(Unknown Source)
Hi List,
This stack traces include Batik, so they are happening either as we write out SVG, or as we are reading a SVG to be used as an icon.
values.
at
at
at
at
at
at
at
at
at
at
at
at
org.geotools.renderer.style.SVGGraphicFactory$RenderableSVG.<init>(SVGGraphicFactory.java:150)
at
at
at
at
at
at
at
at
at
Ok, then it's happening while rendering, and caused by one of the SVG icons
you're referring to in your styles
(or in a dynamic style that some above average user is sending to GeoServer
using POST requests, or using SLDBody)
Hi Andrea,
I’m guessing from what you didn’t say that there’s no way to figure out which SVG is causing it?
Ok, then it’s happening while rendering, and caused by one of the SVG icons you’re referring to in your styles
(or in a dynamic style that some above average user is sending to GeoServer using POST requests, or using SLDBody)
Hi Andrea,
I have request logs; problem is there’s no timestamp on the stdout event. A quick search shows no uses of “sldbody” or even just “sld” anywhere in the log. So I guess it was a locally stored SVG.
Jonathan
I don’t know a ton about batik and its error reporting, but I suggest that you use a find-in-files tool like grep to look for the actual text “param(fill)” in your SVG resources. The message appears to indicate a syntax error in one of your icon files.
Hi Andrea,
Jonathan
