[Geoserver-users] The gwc and "The coordinate reference system must be the same for all objects" error
Hello,
I've set up a layer based on an ImageMosaic store - bunch of GeoTiffs in EPSG:3857 projection with time and custom dimension (indexed by a PostGIS datastore). Two different styles are used - first is a simple RasterSymbolizer with a ColorMap. Second one is based on Transformation with ras:Contour.
Everything works well with standard WMS requests. However, when I switch to GeoWebCache to render EPSG:900913 tiles, the second style (with contours) throws an error:
"org.opengis.geometry.MismatchedReferenceSystemException: The coordinate reference system must be the same for all objects"
The gridset EPSG:4326 is handled by GWC with no errors at all.
Is it a bug I should fill in JIRA?
Regards
Maciej
Geoserver 2.6.2 (2.7.0 RC1 also tested) on Apache Tomcat/7.0.52, Java(TM) SE Runtime Environment (build 1.7.0_76-b13)
Detailed error log:
2015-03-11 09:19:40,596 INFO [org.geoserver.wms] -
Request: getServiceInfo
2015-03-11 09:19:40,596 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-03-11 09:19:40,596 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-03-11 09:19:40,597 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-03-11 09:19:40,597 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-03-11 09:19:40,601 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-03-11 09:19:40,601 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-03-11 09:19:40,610 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2015-03-11 09:19:40,611 DEBUG [org.geotools.jdbc] - SELECT max("time") FROM "public"."PRESSURE_AT_MEAN_SEA_LEVEL_3857"
2015-03-11 09:19:40,612 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2015-03-11 09:19:40,614 DEBUG [org.geotools.rendering] - Computed scale denominator: 3.49426414969308E7
2015-03-11 09:19:40,615 DEBUG [org.geotools.rendering] - Processing 1 stylers for http://www.opengis.net/gml:GridCoverage
2015-03-11 09:19:40,615 DEBUG [org.geotools.rendering] - creating rules for scale denominator - 34,942,641.497
2015-03-11 09:19:40,615 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-03-11 09:19:40,615 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-03-11 09:19:40,616 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-03-11 09:19:40,616 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-03-11 09:19:40,616 DEBUG [org.geotools.rendering] - Expanding rendering area by 6 pixels to consider stroke width
2015-03-11 09:19:40,617 DEBUG [org.geotools.rendering] - added attribute grid
2015-03-11 09:19:40,617 DEBUG [org.geotools.rendering] - added attribute params
2015-03-11 09:19:40,618 DEBUG [org.geotools.rendering] - Querying layer http://www.opengis.net/gml:GridCoverage with bbox: ReferencedEnvelope[-58703.63771484376 : 5068080.722714845, 9960050.532285154 : 1.2582146350214843E7]
2015-03-11 09:19:40,618 TRACE [org.geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2015-03-11 09:19:40,618 TRACE [org.geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2015-03-11 09:19:40,620 DEBUG [org.geotools.gce.imagemosaic] - Reading mosaic from file:/var/lib/geoserver/data_dir/um_data/PRESSURE_AT_MEAN_SEA_LEVEL_3857/datastore.properties
2015-03-11 09:19:40,620 DEBUG [org.geotools.gce.imagemosaic] - Highest res 6917.817807654886 6917.817807654886
2015-03-11 09:19:40,621 ERROR [org.geotools.rendering] - The coordinate reference system must be the same for all objects.
org.opengis.geometry.MismatchedReferenceSystemException: The coordinate reference system must be the same for all objects.
         at org.geotools.geometry.jts.ReferencedEnvelope.ensureCompatibleReferenceSystem(ReferencedEnvelope.java:309)
         at org.geotools.geometry.jts.ReferencedEnvelope.intersects(ReferencedEnvelope.java:512)
         at org.geotools.gce.imagemosaic.SpatialRequestHelper.computeCropBBOX(SpatialRequestHelper.java:565)
         at org.geotools.gce.imagemosaic.SpatialRequestHelper.compute(SpatialRequestHelper.java:243)
         at org.geotools.gce.imagemosaic.RasterLayerRequest.<init>(RasterLayerRequest.java:213)
         at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1132)
         at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:863)
         at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:842)
         at org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:147)
         at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:227)
         at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:217)
         at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:419)
         at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverage(GridCoverageReaderHelper.java:165)
         at org.geotools.renderer.lite.StreamingRenderer$1.readCoverage(StreamingRenderer.java:2005)
         at org.geotools.renderer.lite.RenderingTransformationHelper.applyRenderingTransformation(RenderingTransformationHelper.java:141)
         at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2013)
         at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:820)
         at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:494)
         at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258)
         at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:130)
         at org.geoserver.wms.GetMap.executeInternal(GetMap.java:510)
         at org.geoserver.wms.GetMap.run(GetMap.java:254)
         at org.geoserver.wms.GetMap.run(GetMap.java:125)
         at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:354)
         at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
         at java.lang.reflect.Method.invoke(Method.java:606)
         at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
         at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
         at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
         at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
         at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
         at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
         at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
         at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
         at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
         at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
         at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
         at com.sun.proxy.$Proxy65.getMap(Unknown Source)
         at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:792)
         at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:274)
         at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1174)
         at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:573)
         at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:518)
         at org.geoserver.gwc.layer.GeoServerTileLayer.getTile(GeoServerTileLayer.java:467)
         at org.geowebcache.GeoWebCacheDispatcher.handleServiceRequest(GeoWebCacheDispatcher.java:363)
         at org.geowebcache.GeoWebCacheDispatcher.handleRequestInternal(GeoWebCacheDispatcher.java:254)
         at org.geoserver.gwc.dispatch.GwcServiceProxy.dispatch(GwcServiceProxy.java:98)
         at sun.reflect.GeneratedMethodAccessor139.invoke(Unknown Source)
         at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
         at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
         at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
         at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
         at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
         at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
         at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:439)
         at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:178)
         at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
         at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
         at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
         at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
         at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
         at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
         at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
         at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
         at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
         at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
         at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
         at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
         at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
         at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
         at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
         at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
         at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
         at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
         at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
         at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
         at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
         at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
         at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
         at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
         at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
         at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
         at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
         at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
         at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
         at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
         at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
         at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
         at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
         at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
         at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
         at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
         at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
         at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
         at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
         at org.apache.tomcat.util.net.AprEndpoint$SocketWithOptionsProcessor.run(AprEndpoint.java:2378)
         at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
         at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
         at java.lang.Thread.run(Thread.java:745)
2015-03-11 09:19:40,622 DEBUG [org.geotools.rendering] - Style cache hit ratio: NaN , hits 0, requests 0
2015-03-11 09:19:40,623 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed
         at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:520)
On Wed, Mar 11, 2015 at 9:24 AM, Maciej Filocha <m.filocha@anonymised.com>
wrote:
Hello,
with ras:Contour.
Sounds like a bug indeed... please open a ticket and attach a small dataset
and requests, enough to reproduce the problem
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
W dniu 2015-03-12 o 01:04, Andrea Aime pisze:
Done:
https://jira.codehaus.org/browse/GEOS-6934
Regards
Maciej
