[Geoserver-users] TIFF pyramid and mosaic in 1.7.0
I am running into this when updating geoserver :
v 1.6.5 :
(See attached file: geos map 1.6.5.JPG)
same with 1.7.0 :
(See attached file: geos map 1.7.0.JPG)
v 1.6.5 : a photo
same with 1.7.0 : a white page !
The files are TIFF pyramids (photo) and mosaic (map). Of course, they are
the same, the only thing different is geoserver release.
Any hint on how to get the original colours (and everything else) ?
Thank you,
Christian DUPONT
Ciao Christian,
I am assuming you using the raster.sld style right?
If so you need to update it since otherwise the rastersymbolizer will
pick it up and symbolize your data. Send it over and I'll update it
for you.
Simone.
On Fri, Nov 7, 2008 at 5:10 PM, <christian.dupont@anonymised.com> wrote:
v 1.6.5 :
same with 1.7.0 :
v 1.6.5 : a photo
Thank you,
Christian DUPONT
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
