Does some one has knowledges of how to process the census tiger data to finish the procedure describes here :
http://docs.codehaus.org/display/GEOSDOC/Loading+TIGER+high-level-polygon
There are already :
polygons, landmarks,water and roads
but there are not :
state polygons, county polygon, zipcode polygons, zipcode+4 polygons, economic polygons, cenus polygons
I'm currently working on the TIGER dataload. I was actually going to hold off construting these for a while because they're not trivial and I didnt think anyone would need them for a bit. Each one needs different processing because they store the data differently.
I will eventually get to them. Which ones were you most interested in?
dave
There are already :
but there are not :
I’m interested about the last point of the data import:
- Loading TIGER high-level-polygon future process
- creates the TIGER high level polygon datasets (state polygons, county polygon, zipcode polygons, zipcode+4 polygons, economic polygons, cenus polygons, etc…)
I just need the state polygons and county polygon
2006/3/27, David Blasby <dblasby@anonymised.com >:
I’m currently working on the TIGER dataload. I was actually going to
hold off construting these for a while because they’re not trivial and I
dave
There are already :
but there are not :
I'm interested about the last point of the data import:
1. Loading TIGER
high-level-polygon<http://www.geotools.org/display/GEOSDOC/Loading+TIGER+high-level-polygon>future
process
cenus polygons, etc...)
Those are the two I was considering processing, so hopefully you'll see the instructions (and code) appear in a week or two.
dave
1. Loading TIGER
process
The instructions for processing these are on the wiki now -- let me know if everything works for you.
I just added instructions for putting the state name and county names on them.
dave
