[Geoserver-users] Tile edges issue
Hi everyone, I am experiencing issues where I try to generate a heatmap using a style in which the tile edges show. It is as though the surrounding tiles do not know to render the outer parts of the heatmap. I used the style found here: https://docs.geoserver.org/latest/en/user/styling/sld/extensions/rendering-transform.html
The style in use is the one that renders points into the heatmap. I tried searching for solutions but I don’t know if I am not using the correct terminology.
Anyone have any ideas or suggestions?
Thanks for your help
This is a well known problem and there is nothing that GeoServer can do about it. See https://gis.stackexchange.com/questions/245379/adjust-geoserver-geotools-heatmap-code-to-show-it-as-tiled-wms for a longer explanation
Simple solution is to not use tiles, better solution is to pre compute the heat map and server the result up as a layer.
Ian
Ian Turton
Hi Ian, thank you so much for your guidance, really appreciate it!
Ian
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
