[Geoserver-users] Tile layers setting in geoserver
help me!!! help me!!!
Recently, I meet a problem using geoserver. The problem is that I use the GeoWebCache to cut the map, but getting the cache png map’s gray value is changed and it is changed to 8bit, so that I want to know why. Or if does the geoserver specify the gray value.
Thank you!!!
