[Geoserver-users] Tiles and gridset bug?
I have a Oracle layer that I’ve added. In the “tile caching” I’ve associated it with a Gridset. The problem is, the gridset bounding box doesn’t in any way shape or form overlap the actual layer bounding box. As GeoServer knows the BBox of both layers, shouldn’t it warn the user of this?
Further:
As I hadn’t at this point realised my mistake, I went to “tile layers” and “seed/Truncate” and had GeoServer create lots of tiles for me for this layer. Needless to say, all of them are completely blank.
I realise this is user-error, but is it considered a bug given GeoServer lets the user do something that silly but probably shouldn’t? At the very least it should tell the user the bounding boxes don’t overlap.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
There's only a weak relationship between the bounding box for a feature type and the actual extent for the data. If you add features to your database after GeoServer starts (common, often you start with an empty database) the bounding box will not be updated until you recalculate it, so you should definitely be able to seed / truncate areas outside of this box.
Maybe a warning in the logs, but definitely not anything to suggest a hard error.
-Arne
On 12/27/12 09:49 , Jonathan Moules wrote:
I have a Oracle layer that I've added. In the "tile caching" I've associated it with a Gridset. The problem is, the gridset bounding box doesn't in any way shape or form overlap the actual layer bounding box. As GeoServer knows the BBox of both layers, shouldn't it warn the user of this?
Further:
As I hadn't at this point realised my mistake, I went to "tile layers" and "seed/Truncate" and had GeoServer create lots of tiles for me for this layer. Needless to say, all of them are completely blank.
I realise this is user-error, but is it considered a bug given GeoServer lets the user do something that silly but probably shouldn't? At the very least it should tell the user the bounding boxes don't overlap.
Jonathan
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122712
Geoserver-users mailing list
