I realized, that in version 2.4.3 when using a timeseries (raster) layer,
when doing a KML/KMZ export, the parameters time and elevation are not
passed and not written in the XML file.
Checking the code I found out the problem and resolved it in the class
(org.geoserver.wms.WMSRequests).
If this problem has not been already solved, I can provide a patch.
cheers Markus
View this message in context: http://osgeo-org.1560.x6.nabble.com/Time-parameter-missing-in-KML-KMZ-export-tp5099813.html
On Fri, Jan 24, 2014 at 10:53 AM, markus innerebner <
markus.innerebner@anonymised.com> wrote:
Please do. We can commit patches only with a test around (unless the test
is sort of impossible
to make), so if you can also add a test, that would be much appreciated
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
