[Geoserver-users] TIME parameter Required or Optional?
Hi list,
This one seems like it may be a bug, but I thought I’d ask before reporting it. 2.5.1.
The following query works fine:
http://wppgeog3/gs/ows?LAYERS=Public_Data_DB%3ATRO_ORDERS&TRANSPARENT=TRUE&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TIME=2014-07-29T00%3A00%3A00.0Z%2F2014-08-13T23%3A59%3A59.999Z&SRS=EPSG%3A27700&BBOX=299012.5,224193.75,560987.5,315806.25&WIDTH=1497&HEIGHT=523
However, if I change it to remove the TIME parameter:
http://wppgeog3/gs/ows?LAYERS=Public_Data_DB%3ATRO_ORDERS&TRANSPARENT=TRUE&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27700&BBOX=299012.5,224193.75,560987.5,315806.25&WIDTH=1497&HEIGHT=523
The result is an XML error:
Internal error
Problem visiting TRO_ORDERS visiting TRO_ORDERS.fid-3d3d23d3_14781baaf14_-45fb:java.lang.NullPointerException
null
Looking at the WMS 1.1.1 specification, TIME is an Optional parameter, so it should work fine.
Am I missing something? Should I JIRA it?
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Tue, Jul 29, 2014 at 12:52 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi list,
This one seems like it may be a bug, but I thought I'd ask before
      Internal error
null
Yes, it's optional, the code should apply a default in case it's not
provided.
Yep, with a full stack trace and a way to reproduce it if possible
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea. Jira created.
For reference - http://jira.codehaus.org/browse/GEOS-6591
Jonathan
On 29 July 2014 12:05, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Jul 29, 2014 at 12:52 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi list,
Internal error
null
Yes, it’s optional, the code should apply a default in case it’s not provided.
Ing. Andrea Aime
@geowolf
Technical Lead
