Ciao,
shapefile by default does not support datetime but only date. This is
oart of the shapefile standard if I remember correctly.
You can have geoserver write datetime by using the java option when
you start it, but from that point and on most software will not be
able to read those shapefiles.
-Dorg.geotools.shapefile.datetime=true
check also the info in this page
http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic_timeseries/imagemosaic_timeseries.html
about timestamp support.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Aug 26, 2016 at 3:40 PM, gulfoslides <gulfoslides@anonymised.com> wrote:
When I output a shapeFile using the Geoserver web portal "Layer Preview"
capability I see that I can output my WFS data as shapeFile. My original
data in my postgres database has a time-stamp for each record in my table.
This time-stamp looks like this: 2015-08-25T05:13:22.079+00. When I look at
the .df file in the output shapeFile collection, it looks like the "Day"
value of the time-stamp was output, but the "Time" value of the time-stamp
was dropped.
Is there a way to have the output of the shape file preserve the Day and
Time ?
View this message in context: http://osgeo-org.1560.x6.nabble.com/time-value-of-output-shape-file-from-geoserver-tp5282468.html
Geoserver-users mailing list
