On Wed, Jun 22, 2016 at 9:50 AM, Chris Buckmaster <
chris.buckmaster@anonymised.com> wrote:
The problem I am encountering is, for any dates that fall within British
summer time (GMT Daylight Saving Time), it appears to be moving the actual
date back by one day (i.e. for a date stored as 8th September 1993 in
PostGIS, it is displaying as 07/09/1993 in my HTML / Javascript web
application). The field is not a timestamp field, it is just a date field
so from what I can gather it shouldn’t be storing any information on time
zones?
There was a discussion about this topic on geotools-devel some time ago,
the outcome was that yes, also dates have timezone (not hard to grasp,
e.g., now it's Wednesday here in Europe, but in a few hours it will be
Thursday in Australia). I believe that the outcome was also that it's
useful to add a configuration flag
for those that do not work in an international settings, so that the dates
do not get modified in those cases.
According to the docs there is a system variable you can set:
http://docs.geotools.org/latest/userguide/library/metadata/geotools.html
So starting your JVM with -Dorg.geotools.localDateTimeHandling=true should
change the behavior. It would be nice to have that as a global setting
in the GeoServer UI... anyone interested in coding it?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
