Actually I think I found my answer. In the parseDateTime method in the KMLMapTransformer class, I believe the date is being parsed using the geotools DateUtil.deserializeDateTime() method
In the GeoTools API it mentions:
Date values are expected to match W3C XML Schema standard format as CCYY-MM-DDThh:mm:ss, with optional leading minus sign and trailing seconds decimal, as necessary
Thank You
Dominique
Sent: Wednesday, February 06, 2013 5:02 PM
Subject: TimeSpan KML
Hi
I’m having problems importing my KML from geoserver 2.2 into a map and found it is because the map doesn’t like fractional seconds. (ie. Yyyy-mm-ddThh:mm:ss.fffz) I was looking at the geoserver spec and in the geoserver code, mainly the KMLMapTranformer.java class and the datetime formats don’t include fractional seconds. I’ll continue to debug this but in the meantime I was hoping someone could give me a quick answer as to why the resulting KML includes the fractional seconds, and if anyone could foresee any issues that could arise with removing them in our geoserver instance.
Example KML snippet:
2013-02-06T12:00:00.000Z
2013-02-06T14:59:59.000Z
Thank You
Dominique
