On Wed, Sep 23, 2015 at 2:46 PM, Simó Benedek <universitas87@anonymised.com>
wrote:
Ok, now it seems more clear! So the Tomcat maxThreads number has to be
higher than the ows.gwc parameter in controlflow.properties, right? Or it
has to be more than the sum of ows.wms and ows.gwc?
Higher than the sum I'd say.
And will the ows.gwc parameter affect request to the wms endpoint with
tiled=true instead of the gwc endpoint?
Yes and no, it's more complicated than that. If your request has tiled=true
_and_ it matches exactly, by location, format and request parameters,
a tile that can be cached by GWC, and the direct WMS integration in the GWC
config panel is enabled, then GWC takes it over and may be
limited by the GWC limits, otherwise it's a normal WMS request and it gets
handled by the WMS.
Hope this makes sense.
And oh, I did not code the GWC control flow limits myself, so the above
might be incorrect, and it might be that GWC limits kick in only
if you are using the real tile protocols (WMTS and friends).
I'm cc'ing Gabriel, maybe he knows how things actually work.
And I also wonder if one counts with the number of CPU cores in this
case, is it the phísical or the logical cores? (Sorry if this is a dumb
question...)
Not dumb, I always wonder myself. The extra cores HT give are only useful
for integer number computations, but not for float ones (as far as I know).
I don't have a good answer here, gut feelilng, I'd take the physical ones
and multiply by four.
If you want to have a "real" number instead, load test your server with
increating number of parallel requests, with no limits, and
record when you get the maximum throughput, that's likely the number you
want to set in control-flow
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
